Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 06-27-2007, 07:53 PM   #1
teelamaria
Profile:  Miami , Florida
Rusty Argosy?
We are starting in the process of our first RV renovation. We have been
looking around for a little while and found a couple we liked in our range.
We were about to purchase a 26' 1973 Argosy for what we think is a really
good price, when we noticed the rings of rust around the from and back
window seams. Also some pitting/spots on the front roof area. Does any one
have any experience with rust on these and are we getting in to something
that will lead to a nightmare of problems that need to be dealt with when we
get underneath the skin of it... The rest of it looks like mildew stains
which seem to be workable. The interior is in good shape from what we can
see in the photos.
Thanks for your time.
teelamaria is offline   Reply With Quote
Old 06-27-2007, 07:59 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
Welcome to the forums.
The rust is a common thing with Argosy trailers and motor homes. They have galvanised steel end caps, instead of aluminum on a true Airstream. The paint does not adhere well to the galvanised stell, and will peel off if given a chance. If there are no rust holes, you can sand, prep, and repaint the end caps.
Change is inevitable, except from a vending machine
AIR#2611
Old 06-27-2007, 08:10 PM   #3
teelamaria
So its not the end of the world?
If we do find holes (the Argosy is 1000 miles away) can we use bondo to fill after we sand & prep the area with pore15 or naval grease?
Thank you for your lighting fast reply! In your opinon, is the rust pictured a deal breaker? Any specific products we should get if we go forward?
Old 06-27-2007, 08:29 PM   #4
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Rusty Argosy?
Greetings teelamaria!
Welcome to the Forums!
From the photos, the rust doesn't appear to be exceptionally heavy. The area of greatest concern would be along the seams where the galvanized panel meets the aluminum -- the galvanic reactions of dissimilar metals. I haven't run across an Argosy with rust perforations, but that may be because most that I see have spent the majority of their time in the Midwest where exposure to salt air is minimal.
There are several threads here on the Forums that discuss painting our coaches, and at least two that discuss the issue of preparing and painting the galvanized end caps. Other than a slight difference in the preparation of the galvanized panels, painting the Argosy isn't greatly different than painting an automobile. Painting the end caps is something that needs to be done on a somewhat regular basis -- the original owner of my Minuet indicated that it was something that he had been in the habit of doing about once every five years -- I know that it is a job that I will be taking on in a few days as I get the coach ready for our trip to the Vintage Airstream Club Rally in Breckenridge, CO.
Another issue that could be related to the lack of recent maintenance of the end cap paint is the possibility that the seals around the clearance marker lights and windows may not have been maintained allowing leak(s) to develop. It would probably be wise to carefully check the floor condition in the vicinity of these areas -- the paint condition is not a definite indicator, but it does raise the suspicion.
Good luck with your deliberations!
Kevin
Kevin D. Allen
AIR #827
Old 06-30-2007, 08:51 AM   #5
raebaker06
Profile:  Burlington , Ontario
I too have had rust on my Argosy, I applied OSPHO which turns the rust into phosphoric iron and neutralizes the rust . you must then apply a primer and then paint. OH! first sand the area.
My Argosy is a 1974.
Rust must be attended to immediately.
Rae
raebaker06 is offline   Reply With Quote
Old 06-30-2007, 08:53 AM   #6
raebaker06
How do I make a new post to the repair forums. Please
rbaker@nas.net
Old 06-30-2007, 09:32 AM   #7
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Yea, not a real big concern. Sand, prime, paint and any steps suggested so far and it'd be as good as new.
Stripping an Argosy CHRIS CANNON Cleaning, Stripping & Polishing 7 06-19-2007 11:18 PM
Argosy Motorhome Manual & Brochures WANTED Rik Airstream Motorhome Forums 5 09-26-2006 05:21 PM
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
New Argosy owner! barbwire All Argosy Trailers 33 04-15-2003 07:14 PM
1985 Argosy MH???? 1985air345 Airstream Motorhome Forums 8 03-21-2002 07:39 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
