Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 01-18-2006, 01:51 PM   #1
Profile:
Send a message via Yahoo to atvmcg
rub rail replacement
I need to replace the beltrail and rubrail. The previous owner applied some kind of pinstriping tape that is now cracking and fading and is unsightly. Question is , how do I get the tape off? (por15 stripper?).
atvmcg is offline   Reply With Quote
Old 01-18-2006, 02:02 PM   #2
enduroryda's Avatar
Profile:  1994 21' Sovereign
Down on the corner... , CT
Try a blow dryer...have had good luck removing decals with this method.
enduroryda is offline   Reply With Quote
Old 01-18-2006, 02:40 PM   #3
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Have you tried WD 40? Por Strip is pretty much for plastic coating.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 01-18-2006, 06:46 PM   #4
Profile:
Thanks for the info...I'll try a few methods this weekend and see what works best.
Water heater replacement Craig Water Heaters, Filters & Pumps 35 06-18-2007 06:47 AM
Rub Rail Replacement Question 1985air345 Clearcoat, Exterior Paint & Trim 6 07-06-2003 01:35 PM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
