Old 11-14-2008, 09:33 AM   #1
seeleylaker's Avatar
1968 26' Overlander
Dillon , Montana
Restoring painted exterior
Trying to get back into Airstreams after a long break (69 Caravel in the early 80s-a Bambi prior to that). Not having much luck, but have found a trailer close to home that is painted on the exterior. It appears to be a sprayed on automotive finish of some sort. Has anyone had any luck stripping and polishing this type of surface? I'm concerned that the paint was used to cover something that was very difficult, or impossible to polish. Any inputs appreciated. Need to find a trailer, but need to know I can get it restored. Thanks!
seeleylaker is offline   Reply With Quote
Old 11-14-2008, 09:42 AM   #2
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Intuition = SMART
Your intuition that there is something awful under the paint is probably right. Some people find it is less expensive in the long term to paint - and less labor than polishing every year or so - have elected to paint their Airstreams. Of course there are always "Silver Argosies" too...
At a minimum it's likely the exterior was sanded to help the paint primer adhere. If you aren't prepared to live with a painted Airstream, I'd say pass this one by. (You might consider repainting it if the old finish is dull or faded, but you'll probably regret even trying to strip it.
Paula
Old 11-14-2008, 09:46 AM   #3
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Welcome to the forums! Here is a recent thread on this topic. Good luck with your search, whatever you decide to do.
Mel
Mel is offline   Reply With Quote
Old 11-14-2008, 11:35 AM   #4
1972 Travelux Princess 25
Cobourg , Ontario
I'm assuming this is an Airstream not an Argosy or SOB?
After 20 years in the auto body repair and painting business, I would pass and look for a better one. Unless it was in perfect shape and at least $3000 below market price. Or unless you plan to leave it painted.
Anything is possible, some things just aren't worth doing.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 11-15-2008, 08:53 AM   #5
Cobourg , Ontario
It's a pretty safe bet that there was some body damage that cannot be repaired properly except by replacing panels. To get around this, they fixed it by pounding out the dents smoothing over with plastic body filler and painting as you would a dented car fender.
Now if you want a polished surface you will have to strip the paint, repair any damage then polish the surface. The surface was probably sanded before painting making it about 3 times as hard to polish.
This is why I say it would be more sensible to look for a better trailer.
Old 11-15-2008, 09:44 AM   #6
1968 26' Overlander
Dillon , Montana
Thanks to all for the advice. I suspected there must be a reason for painting, but never really thought about bondo or the sanding. Now I know. And, yes, I'm still looking but the mountain passes around here make me think it may have to wait until spring to get it home. Thanks again!
So, What have 'you' found while restoring?? balrgn Off Topic Forum 148 04-26-2010 09:51 AM
Painted vs Bare Aluminum Exterior Tinsel Loaf Ribs, Skins & Rivets 86 11-25-2007 12:05 PM
Restoring Exterior Badges neillop Clearcoat, Exterior Paint & Trim 7 07-17-2007 06:16 PM
How much did you spend restoring your AS? Boondocker Our Community 24 09-06-2005 05:26 PM
aluminum restoring rdm Cleaning, Stripping & Polishing 1 02-27-2002 11:37 AM
