Old 08-27-2007, 08:18 AM   #1
StingrayL82's Avatar
San Angelo , Texas
Images: 37
Restored Emblems
Hello Everyone,
Well, I finally got around to doing the one thing that South Jersey RV didn't do, when they redid our Sovereign, which I was a bit PO'd about, considering the money I spent on the refurbishing...I won't even call it a restoration, because restoration implies that everything is back to like-new condition.
I was bored, and the emblems were looking bad, so I took some 400 grit sandpaper and sanded the side emblems to metal, being careful not mess up the chrome. When everything was smooth, I primered the whole emblem and let it dry. Then I painted the whole emblem white and let it dry. Then I masked everything off, except the red part and painted that red and let it dry. Then I masked everything off, except the blue part and painted that blue and let it dry. Then I took off all the masking and scraped off the lettering with my fingernail, to expose the chroming. Judge the results for yourself.
I also did the emblem by the door. It needs a tiny bit of touch up, and I need to figure out how to get the blue inside the lettering. Any suggestions are appreciated.....the automotive touch up brush is too big.
While I was at it, I took automotive touch up paint and did the rear "International" lettering. The only reason I knew that the outside border was even blue was because I found a small spec of blue in the capital "I".
I know the blue is not "Airstream Blue", but the blue I found looks nice.
All comments are welcome.
Frederic
Name:	Curbside Emblem.jpg
ID:	43970   Click image for larger version
Name:	Front Curbside Emblem.jpg
Name:	Rear Emblem.jpg
ID:	43972   Click image for larger version
Name:	Roadside Emblem.jpg
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 08-27-2007, 08:22 AM   #2
SwampBillies's Avatar
1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
Send a message via AIM to SwampBillies
I think they look fantastic!! Great Job!
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Old 08-27-2007, 10:14 AM   #3
San Angelo , Texas
Images: 37
Thanks. The roadside turned out better than the curbside, because the first can of white spattered when it came out, and I to start all over. I took my time on the roadside.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 11:49 AM   #4
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi Fredric
I did the sam thing on my AS trailer. I use a sal brush to redo the letters. Anything that was in one unit I took of and spayed in on the ground. To keep the silver form being painted I used vasline on sections that i wanted to stay silver.
Regards from Russell in hot and humit Tucson Az.
RUSSELL is offline   Reply With Quote
Old 08-27-2007, 11:56 AM   #5
San Angelo , Texas
Images: 37
So if I mask off the area, smear vaseline on the silver parts and spray the letters blue, the silver area will be unaffected? I never thought of that. Very clever indeed! Thanks for the tip, Russell; I'll try it and post results.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 12:28 PM   #6
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Vaseline & POR 15?
Will the Vaseline trick work on POR 15? I'd rather smear my arms and face with Vaseline then try a face mask, long sleeves and rubber gloves in Virginia's summer.
Paula
Paula
Old 08-27-2007, 12:40 PM   #7
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Paula
Paula
I have used a product before - I will have to research the name - I think it was called Liquid Gloves. You just apply it like hand cream before starting a nasty job like painting and then when you wash up the paint comes off real easy. Had it in a garage I worked in years ago, worked real well with grease and gasket adhesives.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 08-27-2007, 03:07 PM   #8
San Angelo , Texas
Images: 37
I remember my Dad having something like that in the garage, when I was a kid in the 70's.
Frederic
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 05:32 PM   #9
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Looks great. So you were able to remove the paint from the raised letters by simply scraping them off with your fingernail? Hmmmm.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-27-2007, 05:40 PM   #10
San Angelo , Texas
Images: 37
Yes, and may I say that the fleshy part between the nail and the thumb was quite sore the next day!
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 05:59 PM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You're gonna love this way...
Why not paint the entire area, including the letters, the color you want the letters to be, then sand off the flat (outside) part, then pain the outside part the color you want.
Old 08-27-2007, 06:02 PM   #12
San Angelo , Texas
Images: 37
Because the letters are chromed.
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 06:05 PM   #13
San Angelo , Texas
Images: 37
Oh, wait, I see, you mean the emblem that says Airstream and Sovereign....the problem is that once the letters are painted blue, how do I paint the outside? I'm not masking the letters!
Frederic
AIR # 8239
EX-WBCCI # 8371
Old 08-27-2007, 06:06 PM   #14
clancy_boy's Avatar
Kiln , Mississippi
Images: 8
I believe he is talking about the Sovereign emblem. That way the grove cut leters will be filled and the flat will be what ever color you want which I believe was silver on the original emblem.
Restored '65 GT for me. soldiermedic 1965 - 1969 Globetrotter 31 08-14-2013 02:32 PM
Should older airstreams be restored OR customized? imeynstein Community Polls 65 09-29-2011 09:26 AM
1973 Argosy Fully Restored pclois Member Introductions 1 06-28-2007 09:19 AM
Restored Texas Style azflycaster Off Topic Forum 36 06-19-2007 08:33 AM
'54 17' Restored on ebay! 63Airstream Off Topic Forum 3 12-24-2006 07:45 PM
