Old 11-04-2015, 08:33 PM   #1
Harper , Texas
Removing Decals
Does anyone know how to safely remove a decal from the exterior without damaging the aluminum? I tried Airstream's process, didn't work at all. (WD40 & Slick 50. Lubricant)
bencamp is offline   Reply With Quote
Old 11-04-2015, 08:43 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
Is your trailer clearcoated, in good shape or failing, are you planning to strip it? Just need a little more info
reinergirl is offline   Reply With Quote
Old 11-04-2015, 08:43 PM   #3
richw46's Avatar
Lexington , Kentucky
I use a hair dryer to warm up the annual registration sticker on my boat before I remove it. Have you tried removing it after it's been in the hot sun, then applying the WD40 and lube?
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is online now   Reply With Quote
Old 11-04-2015, 09:10 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I use a heat gun on low, be sure to not get the tip too close or linger in one spot too long.
MICHAEL
Old 11-04-2015, 10:48 PM   #5
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
3M Adhesive Eraser Wheel
Rich Luhr was successful last February in removing his large decals by using 3M Adhesive Eraser Wheel and following up with Goo Gone.
Read the details in his blog post, "Oh no, it's the UPS truck again."
And see his demonstration:
His video, "Removing adhesive decals from an Airstream travel trailer," can be viewed on the YouTube website:
SilverGate is offline   Reply With Quote
Old 11-05-2015, 03:31 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Auto paint stores carry a decal remover that works pretty well on MOST decals. Spray it on, wait for it to work, and peel the decals off.
Brevi tempore!
Old 11-05-2015, 06:51 AM   #7
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I've used the eraser wheel that SilverGate is recommending and have tried at least 10 other methods. Go straight to the eraser wheel and save yourself a lot of time and frustration. Most auto body repair supply stores carry them.
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 11-09-2015, 03:51 PM   #8
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
http://www.airforums.com/forums/f474...ml#post1596351
thesignlady is offline   Reply With Quote
Removing interior vinyl panels: rivet-removing tool? What's underneath? Ellie25ftSov Upholstery, Blinds, Walls & Interior Finishes 2 08-20-2014 09:34 PM
removing WBCCI number decals loft47 Cleaning, Stripping & Polishing 9 02-10-2010 10:22 PM
Removing Numbers and Decals Phil Tribby Cleaning, Stripping & Polishing 32 07-24-2009 07:08 AM
Removing AIRSTREAM Decals popeyedoyle1 Clearcoat, Exterior Paint & Trim 9 06-23-2006 01:21 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 11:47 PM
