Old 11-09-2007, 09:35 PM   #1
Pete Salvesen's Avatar
Remove Decal
I have an 89 Excella with the blue decal stripe around the exterior. I need some advise on how to best get this decal off. Thanks, Pete
Pete Salvesen is offline   Reply With Quote
Old 11-09-2007, 10:14 PM   #2
Excella3287's Avatar
Decal
Hello Pete and welcome, just finished removering the BLUE decal today using Jasco paint and varnish remover. Bought at Home Depot make sure that you have gloves its nasty stuff, goes on thick wait 5-10 minutes then pull off. At times it does leave the glue remaing which can be rmoved by using acetone. there are plenty of threads on this subject, use the search tool and you will find many. good luck
Excella3287 is offline   Reply With Quote
Old 12-28-2007, 08:55 PM   #3
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
I took mine off with a pressure washer.
Ramp is offline   Reply With Quote
Old 12-29-2007, 04:34 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
You can soften the glue with naptha (charcoal lighter) which is cheaper, less volatile, and less explosive than Acetone. By itself, it is not strong enough to penetrate the big decal but is good for clean-up. A hot air hand blower that is commonly used for stripping paint (looks like an industrial hair dryer) will soften the decal without the danger of the heavy duty solvents. Just heat the decal and use a dull putty knife to lift it. Razor blade scrapers are too sharp and scratch the aluminum.
Old 12-29-2007, 06:20 AM   #5
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
my sovent of choice is denatured alcohol. Same family as Acetone and MEK but not as strong.
Michelle TAC MT-0
Sarah, Snowball
Old 12-29-2007, 07:32 AM   #6
Airstreamin and luvin it
Devoman's Avatar
Northwest Panhandle , The Sunshine State/WBCCI 6637
Blade
If you want to scrape it off and use a heat gun,Go to you nearest sign shop and ask them if they have some plastic razors to sell you or you can talk to them about how they take old vinyl off.There are many ways to do this without hurting the vehicle and using strong solvents.
CHANGE IS GOOD.LIFE IS GREAT!
It just cant get any better than that.
Devoman is offline   Reply With Quote
Decal Removal Help Ganglin Cleaning, Stripping & Polishing 11 09-15-2007 06:52 PM
AIRSTREAM decal ricochet Clearcoat, Exterior Paint & Trim 3 04-07-2007 11:51 AM
AIR decal davidz71 Our Community 4 09-02-2005 11:43 AM
Decal Over59 Community Polls 41 04-01-2005 06:37 PM
Woodgrain Decal Help? jthew1 General Motorhome Topics 33 01-18-2004 05:04 AM
