Old 07-31-2016, 12:14 PM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
remove clear coat and re coat one panel at a time.
The upper half of my trailer, particularly the end caps, are pretty well sun scalded or oxidized. I tried stripping a small area with Ctristrip and it worked well. The Al underneath is a little discolored but not bad. I do not want to polish the trailer. It is a 88 model and sorta rough in lots of spots anyway. I just want to get rid of the crummy looking clear coat and get something on it so I do not have to do it every year.
I am going to try stripping and recoating one panel at a time.
What would be a good material to clear coat with? Plasticote clear laquere? Is there a Al clear coat that comes either in liquid or aerosol form?
Short of polishing with a Cylco (I just don't want to get that dirty and hot) is there a way to blend it out with something like automotive wet or dry or some other technique.
Bill M. is online now   Reply With Quote
Old 07-31-2016, 12:47 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I used this. 2 cans for one end cap.
http://odmrv.com/catalog/index.php?m...roducts_id=866
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 07-31-2016, 01:22 PM   #3
1988 25' Excella
1987 32' Excella
Thanks A. W. I just ordered the 4 cans they had in stock. Hope they can get more. I looked for it in the Airstream store and it was not there.
Did you do anything to clean up the Al after stripping? Or just strip and recoat?
Bill
Old 07-31-2016, 01:24 PM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I believe Sikkens makes a single stage clear that has direct application on aluminum which will work.
AtomicNo13 is online now   Reply With Quote
Old 07-31-2016, 02:40 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Bill
It's been a few years, but as I remember: I pressure washed with water to get the stripper out of the crevices. Then I cleaned with mineral spirits and a plastic scrub pad before wiping down with micro fiber cloth.
Alan
Old 08-01-2016, 12:13 PM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I've been hearing some good things about Nyalic for recoating Airstreams. I've had no experience with it, so I can't vouch for it, but their website is impressive..
http://www.nyalic.com/
For whatever it's worth..
Larry C
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 08-01-2016, 12:52 PM   #7
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
I've used Nyalic to recoat the cast aluminum pieces and also re-clear coated areas where filiform was removed and re-silver painted. The product sprays or brushes nicely. It's a polymer base and is used on painted or bare aluminum. The company told me they know of two Airstreams completely re coated with their product. Their website covers uses and they will talk if you call.
Howard L. is offline   Reply With Quote
Old 08-01-2016, 02:37 PM   #8
1988 25' Excella
1987 32' Excella
http://www.nyalic.com/assets/images/PIC%20AIRSTREAM.jpg
I did find a picture of a very good looking Airstream on the nyalic website. I am impressed.
Thanks for the tip
Is it ok to only strip clear coat and not polish? rothway Clearcoat, Exterior Paint & Trim 24 08-02-2016 07:05 PM
clear coat or plastic coat fpoulson Cleaning, Stripping & Polishing 1 10-26-2014 12:42 PM
clear coat remove & polish? confused tempest2 Clearcoat, Exterior Paint & Trim 8 07-13-2010 12:39 PM
Has Any One use microbille on clear coat? Perry Cleaning, Stripping & Polishing 6 12-10-2007 03:42 PM
Clear coat cleaning and protection ricksre Clearcoat, Exterior Paint & Trim 21 03-19-2005 06:00 AM
