Old 04-02-2012, 08:33 AM   #15
Erik Olson's Avatar
1974 29' Ambassador
CONCORD , North Carolina
Images: 20
Send a message via Skype™ to Erik Olson
My 1974 Ambassador looks like there is no attachment method from the outside, but I'm going to give the putty knife method a try after pre-drilling for blue rivets. I am searching for this too, but what method is the easiest and gives good results for painting? Do I simply spray the entire letter, then use a solvent to remove paint from the raised edge?
I've been taping the International placard off for the red and blue flag areas, but the big white field with the International area in it will certainly be more difficult.
Erik Olson
1974 Ambassador 29' Ohana
www.tradingpathmedia.com
Erik Olson is offline   Reply With Quote
Old 04-03-2012, 09:45 AM   #16
JFScheck's Avatar
Rockville , Maryland
Images: 33
and to think - I'm trying to keep mine from peeling off! ;-)
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-03-2012, 11:42 AM   #17
The flags and letters on your Airstream, all had small posts on the backside.
Then, holes were drilled to match the location of those posts.
The flags,letters were then inserted into the holes, and a speed nut was slid over those posts to hold those parts in place.
Using a putty knife will remove them with ease.
Reinstall them using pop rivets, and of course some sealer.
Old 04-30-2012, 07:31 AM   #18
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Have a question about the letters:
1. How would one re-attach the letters with pop rivets without drilling holes through the front of the letters, thus exposing the pop rivets on the front? I removed my letters from the back and most still have the posts, but a few broke off since they were so corroded. I know the small sighs use rivets, so I'm good there, just not sure about the letters, epoxy?
Eric H is offline   Reply With Quote
What's the best way to polish between letters? Tidal Cleaning, Stripping & Polishing 4 09-20-2007 08:24 PM
Airstream Letters 75 Sovereign ostapbender Cleaning, Stripping & Polishing 3 08-22-2007 05:24 AM
how to paint letters on 1970 airstream? happydaze Clearcoat, Exterior Paint & Trim 6 03-01-2007 06:24 AM
White Plastic letters for airstream grogan Clearcoat, Exterior Paint & Trim 1 06-25-2003 01:35 PM
Looking for letters FrankR Our Community 6 10-14-2002 06:16 PM
