Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-20-2002, 06:06 PM   #1
tenrsingr
tenrsingr's Avatar
Profile:
Thumbs up Refurbished International Plates
Here is a picture of what my results were after stripping off the old paint and repainting. It took a week to complete. I guess I should have taken before pics.
What do you think?
Steve_in_Savannah
'72 31' International Sovereign
1999 5.4L Ford F150 Lariat Ext. Cab
wife & cat
tenrsingr is offline   Reply With Quote
Old 05-20-2002, 06:10 PM   #2
Action
Moderator dude
Action's Avatar
Profile:  1966 26' Overlander
Phoenix , Arizona
Images: 13
International Plate
Those look awesome! What colors did you use?
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
Old 05-20-2002, 07:27 PM   #3
niftypkg
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Thumbs up International Plates
They look great!! How about sharing the method. I assume they are made of AL. Are those pins I see in the corners the way you remove them? What paint did you use?? Mine are pitted.
niftypkg is offline   Reply With Quote
Old 05-20-2002, 09:15 PM   #4
tenrsingr
tenrsingr's Avatar
Profile:
methodology
Items used -
1. Blue Paiters tape - to tape off areas to paint the blue and red.
2. Aircraft Paint remover - from walmart - in the automotive paint
area.
3. Testors Spray Paint
a. 1258 - Flat white
b. 1210 - Gloss Bright Blue
c. 1203 - Red
Steve_in_Savannah
wife & cat
Old 05-20-2002, 09:21 PM   #5
tenrsingr
tenrsingr's Avatar
Profile:
Paint Removal
Remove paint with the remover..
!!!! Do this outside !!!!
Follow directions and get all the paint off.
Now I washed the plates with soap and water and scrubbed to make sure the remover was now removed.
Now Paint.
Steve_in_Savannah
wife & cat
Old 05-20-2002, 09:29 PM   #6
tenrsingr
tenrsingr's Avatar
Profile:
Painting
Before painting I used vaseline to grease the shiny plated areas to prevent any white paint from sticking on the lettering and the ridges.
1. White -
Full coverage with white paint and painted again within 3 hours. Let them set for 48 hours and paint a last time.
Allowed 18 hours to dry, well had no choice.. I had to sleep and go to work the next day.
2. Next I taped off the areas so that I could paint next color. The
blue and the red I only sprayed two coats within 3 hours and allowed 24 hours to dry for each color.
Now I just cleaned off the white paint and buffed up the shine.
Thats it... this is my result.
Believe me, I was pleasantly suprised.
Steve_in_Savannah
wife & cat
Old 05-21-2002, 09:35 AM   #7
83Excella
83Excella's Avatar
Profile:
Steve,
I see how your nameplates turned out, really a first class job, congratulations.
83Excella is offline   Reply With Quote
Old 05-21-2002, 09:48 AM   #8
moporolo
moporolo's Avatar
Profile:
Question? Did you remove the nameplates first or did you leave them on and mask around them. If you removed them, how - and how did you put them back on - rivets?
moporolo is offline   Reply With Quote
Old 05-21-2002, 10:21 AM   #9
tenrsingr
tenrsingr's Avatar
Profile:
When I aquired my airstream, they were all missing except for the one that has make model serial number on it on the front of the trailer. I have been in search of these for a while.
I traveled to a destination in Florida, a RV Salvage yard, to get these plates. They were removed from a 73 tradewind if I am not mistaken. These plates were riveted to the TT in the corners. I noticed after they were removed that this was the way they were installed as there were no other holes beneath the plates.
The location where mine were removed, there are six large holes with some type of rubber grommet or similar piece with the stud still in .
So there ya go... I plan on attaching my plates this weekend.
Steve_in_Savannah
wife & cat
Old 05-21-2002, 10:27 AM   #10
moporolo
moporolo's Avatar
Profile:
Thanks for the prompt reply - we must have been "surfing" the site at the same time. Great job on the restoration...tempted to do my nameplates (though not International)soon.
Old 05-21-2002, 10:13 PM   #11
tenrsingr
tenrsingr's Avatar
Profile:
Arrow hubcaps next...
I plan on trying to do something with those hubcaps... I wish I had a picture to show me what they looked like initially. The paint is faded to where you really cant tell what color it is. It looks about all grey now...
Anyone have an idea?
Before and after shots on that one...
Steve_in_Savannah
wife & cat
Old 08-11-2005, 03:07 PM   #12
sovereignrwe
sovereignrwe's Avatar
Profile:  1972 31' Sovereign
Oakdale , Minnesota
Ok...so since it has been over 3 years (figure that is enough time) have you by chance finished the hubcaps and have pics to share?
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-11-2005, 06:31 PM   #13
niftypkg
niftypkg's Avatar
Cornville , Arizona
Hub caps, etc
Yes it has been 3 years and I still have the AS. Since that time I have moved to Az. Because of the move, work has been haulted. I had thought that I may sell this one until I looked around and saw a lot of JUNK. I'll keep my own JUNK. The interior had been re-apholsted. And I just finished repairing ( not replacing) the last tombour door under the sink. A previous owner replaced many others. NOt an easy job. Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
Bambi or International? Marya Ashworth Our Community 17 04-12-2005 12:20 PM
International? 59toaster Airstream Trailer Forums 10 03-28-2004 03:33 PM
2004 International at Lansing, MI Edie WBCCI Rallies 6 03-25-2004 10:25 AM
2004 International CCD 25C Lug Nut Airstream Trailer Forums 4 07-16-2003 08:24 AM
discounts on International CCD/AS models blamejane 2003 International CCD 15 06-16-2003 03:54 PM
