Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 10-18-2009, 02:33 PM   #1
Profile:  Mystic , Connecticut
Problem with clear coat erosion
I have just purchased a 2004 Bambi and seek advice about how to deal with erosion spots at the seams, external light fixtures, and door hinges. Can these spots be removed? If not how do you keep this problem from spreading?
gkcarpenter is offline   Reply With Quote
Old 10-18-2009, 02:58 PM   #2
Profile:  2008 25' Safari FB SE
Crawford , Colorado
Welcome. This thread: Corrosion problems with new Airstreams discusses this problem at painful length. Prepare to spend the next week or so plowing through it. Many possible answers, conjecture, opinions, and confusion are present.
Gene
CrawfordGene is offline   Reply With Quote
Old 10-18-2009, 05:08 PM   #3
Airslide's Avatar
Profile:  2001 30' Limited
Novato , California
Images: 47
Send a message via Yahoo to Airslide
Sorry gkcarpenter,
I bet your sorry you asked....
Welcome to the forums anyhow.. congrats on the Bambi.. sucks about the corrosion part. In time you get over it.. I think..
Vinnie
2001 Airstream 30' S/O 70th Anniversary
1994 F-350 Crew 7.3 IDI Turbo, C6, Dually
Airslide is online now   Reply With Quote
Old 10-18-2009, 08:26 PM   #4
BDandTTs's Avatar
Profile:  2005 22' International CCD
Huntington , Vermont
Images: 49
GK,
Welcome! to Airstreaming and the forum!
Lest you get too overwhelmed too quickly, you should know that many relatively new Airstreams have corrosion in the spots that you describe. The Corrosion thread referenced above explains a number of attacks that owners have mounted to get rid of it, or at least to stop the spread.
We wash our trailer frequently, have started spraying the filiform areas with Corrosion-X, and wax at least once per year. The small areas affected around our beltline and rivets have not grown in the last 3 years...and I keep my fingers crossed.
Bob, Dianne, and Tess the WFT
BDandTTs
Bandit #14576 (WDCU/AIR)
http://www.RWChatelain-Woodturner.com
BDandTTs is offline   Reply With Quote
Old 10-18-2009, 10:53 PM   #5
OB Bambi's Avatar
Profile:  2006 19' Safari SE
San Diego , California
I have roughly the same answer as BDandTT's. I think that my filiform problem hasn't changed in the last year or so. I think besides using the Corrison-X and BoeshieldT9, just by waxing it more---especially along the belt line has stopped the corrision. Good Luck (BTW all I use is Turtle wax soft paste wax).
Randy
OB Bambi is offline   Reply With Quote
Removed the clear coat...what now? papagord Cleaning, Stripping & Polishing 18 09-10-2009 10:28 PM
Clear Coat Peeling lsmith Clearcoat, Exterior Paint & Trim 9 07-17-2009 07:32 AM
Clear coat flaking not a problem with 2003 or later models? bgowen Clearcoat, Exterior Paint & Trim 7 03-16-2009 12:48 PM
clear coat in patches safari 28 Ribs, Skins & Rivets 4 05-15-2008 10:29 PM
Clear Coat on Everything! Sherry S Upholstery, Blinds, Walls & Interior Finishes 2 08-07-2007 09:13 PM
