Old 07-09-2012, 07:32 AM   #15
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
As long as you are using POR-15 silver paint and not POR-15 Stirling Silver topcoat as your base, you will have no bonding issues at all. Everything just needs to be clean (very clean) and then painted in two thin coats. When you topcoat, remember you cannot let the POR-15 dry entirely before topcoating. Follow the directions explicitly, but in general just topcoat when the POR-15 is still tacky. Tacky is defined as "dry to the touch but with a slight finger-drag remaining."
Originally Posted by Spit View Post
for my first coat of Por-15 i was planning on getting gray to provide some contrast for the second coat. However i have some other hardware that needs painting...door hinges etc. so maybe i'll get the silver for the first coat and use what is left for the hardware.
will silver be a good first coat? will the 2nd and top coats bond as well to it as they would to the gray coat?
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Tow vehicle needed: 4x4 truck jornvango Tow Vehicles 50 12-23-2013 12:39 PM
Spartan Mansion 33 :: 1950 Airstream Spartan Mansion j2m Airstream Registry Discussions 0 01-28-2012 09:38 AM
Spartan 23' What's it worth? Mr & Mrs S Trailer Values 12 12-30-2011 07:14 AM
1946 Spartan Manor DavidsonOverlander Vintage Kin 12 10-20-2011 07:25 PM
PLEASE POST YOUR THOUGHTS!!! Spartan!!! Eric H Off Topic Forum 9 10-15-2011 06:46 AM
