Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 02-26-2004, 08:53 PM   #1
gsymes
gsymes's Avatar
Profile:
POR paint inquiry
I am almost ready to paint my tongue, Whoa back up my 74' Airstreams tongue and rear bumper. On the POR paint site I see Sterling Silver and Gray kits. I remember a post that showed the gray on the tongue (tastefull) not a overstatement, "like dont talk to me I'M a A/S owner". I would like to see one that shows the Sterling silver. Any help would be appreciated.
Regards Greg
Life is like an Airstream, we always have the potential to shine
gsymes is offline   Reply With Quote
Old 02-26-2004, 08:58 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
I used Stirling on ours...check out "During/Hitch" if you want more pix & info ~
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
InsideOut is online now   Reply With Quote
Old 02-26-2004, 09:22 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
POR 15
If you can wait until tomorrow, I will post a picture of a Sterling tongue and a gray jack.
In the meantime, the Sterling is very difficult to apply without sagging. This causes the silver to have bands of bright and dark silver. I plan put a final coat on with a spray gun, see if it is more even.
The gray is really nice. I used it on some underbody parts and it looks great.
Old 02-26-2004, 09:43 PM   #4
campcollector
campcollector's Avatar
Profile:  2003 19' Bambi
Lincoln City , Oregon
Images: 21
Duraback instead?
I live on the coast and everthing rusts Fast fast fast over here. I bought a gallon of grey duraback truck bedliner paint and plan on using that for the tounge.
Also the POR paint website had a deal were you could get primer and paint together at a discount. I got silver to paint my marker lights because the salt air oxidize's them, havn't tried it yet but hope it helps.
"No good dent goes unpunished."
campcollector is offline   Reply With Quote
Old 02-26-2004, 10:04 PM   #5
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
Hmmm...I didn't have that problem. The "streaks" flowed out just fine as it dried. Might be climatic differences...?
I'm happy with the results ~
Shari
Old 02-27-2004, 08:44 AM   #6
markdoane
Images: 59
POR paint
Greg,
Here is a picture of my tongue/oops, I mean my trailer tongue, with Sterling Silver topcoat on the coupler and POR15 gray on the jack.
I should point out that the gray is the POR15 basecoat, and may change color after exposure to UV. I don't think POR has a gray 'topcoat'.
The Sterling silver is applied over two coats of POR15 silver basecoat.
I reviewed Shari's pictures and she said the paint set up in about 20 minutes. Mine took at least two hours to set up and I think that may be why mine has a streaky saggy look. POR paint is very moisture sensitive, so I think Shari's comment about climatic conditions is right on. It was very dry when I painted, delayed the setting. Took almost 12 hrs to dry completely.
Old 02-27-2004, 05:04 PM   #7
gsymes
gsymes's Avatar
Profile:
Thanks to all, one more question
Pint kit or quart kit for the tongue and bumper? You all sold me on the sterling silver. Mark no wonder you cant get garlic, how far did you have to dig down to get the picture? LOL
Regards Greg
Old 02-27-2004, 05:11 PM   #8
markdoane
Images: 59
POR 15
Greg:
A pint is not enough, a quart is too much. Depends on how many coats you want to put on. Order a six pack of pints. Mix and match the colors. DON'T GET THE QUARTS, because the lids are put on so tight you practically destroy the lid to get it off. And then you can't keep the left-overs.
Also, check local suppliers. Especially in larger cities you can buy single pints
Non-contributing deadbeat.
Old 02-27-2004, 07:01 PM   #9
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
...the lids are put on so tight you practically destroy the lid to get it off. And then you can't keep the left-overs.
I found that if I put a piece of Saran Wrap over the can before putting the lid on, I could get the lid off later. I actually cut a piece of Saran Wrap about 12"x12" then folded it into a 4"x4" square then put it between the lid and can. The top layer would stick to the lid and the bottom to the can, but at least I could keep it fresh between coats...it lasted over the couple of weeks it took me to do the rear bumper, hitch & steps a couple of coats each. It also saved a couple of bucks by buying the quart size...I use two of each the top & base coats...sometimes three of the base coat if it was a really rough area with rust.
Shari
