Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-25-2005, 09:44 PM   #1
Jim & Susan
Jim & Susan's Avatar
Profile:  1973 27' Overlander
McDonough , Georgia
Images: 37
POR-15 Question
There's lots of information on the forums about POR-15. I've found the web site for the product thanks to a link on Balrgn's personal web page. I've read about various other places to purchase the product and many suggestions on proper use/application/etc.
The question for forum members is this. Can y'all point me to a few prior threads that you might consider "all encompassing" or "knowledge base" type of references that you feel would be helpful? There's a lot of good information in the threads, it's just overwhelming sometimes because there is so much information. As always, thanks in advance.
What is that line from "Miracle on 34th Street"? Something like "Maybe he's only a little crazy, like those men in Washington."
www.nesa.org
Air No. 6427
Old 05-25-2005, 09:47 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Try using the 'search' tool to narrow your reading material to topics you might be interested in.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 05-25-2005, 09:58 PM   #3
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
I have used the black and silver. The silver "fills" better and gives a glossy almost glassy surface. The Black seem to "soak in " better.
It's really rather less complicated than it seems.
Assuming the metal is structurally OK.
Steel bush off flaky rust ( don't kill yourself just bush off what's loose) , clean the metal, let dry, treatment solid heavy rust with metal ready, dry well, then por. OR.... just por it. New metal must be cleaned well and treated with the metal ready for the por to stick. Surface rust helps it work. After my frame was sandblasted I let it develope surface rust before painting with the por per the por guy. All have their directions. It is real important to read them. Call the Por 15 number they are very helpful. My 26 foot frame used two quarts. Do Not let any water including sweat, beer ect get into the por can. Do not put the lid back on the por can without a freezer bag between the lid and the can.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 05-26-2005, 04:38 AM   #4
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Results
Thanks for lookin at the page. I need to put some more detail there I think. What we found with the White Coat was it dries VERY fast in the humid weather. Make absolutely certain you have removed any and all silicone sealant. Any residue left the product will not adhere in that area. We cleaned the surface with lacquer thinner prior to application.
Mix no more than you can apply in ½ hour, it sets up rapidly.
The more humid the faster it will set up, which is bad, due to shrinkage.
Tried 2 size nozzles, a 1.2 does not cut it, it atomizes and dries almost upon application. 1.6 to 2.0 (primer nozzle) work great. DO NOT try to use heat or heat lamps to assist in the curing, again it causes shrinkage. (tried it) They are not kidding about a 24 hour cure. After 72 hours mine was ROCK hard. (dropped the portable drill with a bit in it, no mark whew!)
We will be doing the Argosy with a paint brush as there is no need to remove anything. We did a test, the product lays out great no brush marks, but that was a small area...
Hope this helps, good luck!
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 05-26-2005, 07:36 AM   #5
fireflyinva
fireflyinva's Avatar
Profile:  1961 22' Safari
Vienna , Virginia
Also Consider Eastwood's Rust Encapsulating Paint...
In the just for what it's worth column, I recently tried Eastwood's rust encapsulating paint after getting rave reviews from three different guys I know who fix up old cars.
Its formulation appears to be relatively similar (just like POR,-15, any specks won't wash off the skin). I liked it for three reasons--the paint does not need UV protection in any color, the paint is also available in spray cans (Balgryn, I never want to clean this out of a sprayer, you are brave! ), and finally, even with regular shipping, I got supplies from them the day after ordering (nb they are somewhere in PA, I am in the DC area).
Prep is the same--brush off loose rust, a hose down is probably also good if there's lots of loose stuff. Then just paint away.
I think that both are very good paints, I just find the Eastwood product a tiny bit better. I wouldn't throw out any POR-15, but you may want to check it out see if it might be more suited to your use if you haven't already started buying paint.
Mary
Mary Dotson, WBCCI/WDCU #9026
Our Airstream reconstruction adventure continues! Read the details at Tales of the Toaster
fireflyinva is offline   Reply With Quote
Old 05-26-2005, 09:31 AM   #6
balrgn
balrgn's Avatar
Images: 74
Mary
No worry, don't let that thought slow you down. This stuff cleans 100% and easy with enamal reducer. However I am the lucky one, I have a brother in the autobody bidness. He is my go to guy for paints...
www.balrgn.com
Old 10-26-2005, 05:15 PM   #7
Jim & Susan
McDonough , Georgia
Images: 37
Mary
Firefly, i've decided to try this on my frame. That link is pretty convincing. And it's a bit cheaper and appears a bit easier to use. Let me know if you think it holds up well. I'll post some pic's as it goes along.
www.nesa.org
Air No. 6427
Question re new floor fitting on our 1958 Traveller williamhenshall Repairing/Replacing Floor &/or Frame 9 06-30-2004 03:08 PM
Skylight part question ColtSAA45 Roof Vents, Skylights & Fans 3 04-22-2004 08:05 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Tire sizing question caadoptees Tires 5 07-02-2002 10:19 PM
