Old 06-01-2006, 08:37 PM   #1
1959newbie's Avatar
Hill Country , Texas
POR-15 products and frame prep
I've got my 1959 Overlander stripped to the frame now, hope I can get some quick answers before I go into the city tomorrow afternoon for supplies.
Can anyone give me some idea of how much Marine-Clean, Metal-Ready, and POR-15 I'll need to clean and treat my 26' frame? Are two coats of POR-15 needed, then one of topcoat?
Also, what have you found to be the best way to get rust and paint off the frame? I've worn out one thick, stiff wire wheel on my grinder, it seemed to work well in the beginning, less so as it got chewed away. Wire cup brush on a drill does OK in some areas. Tried a big loose wire wheel on drill, it did nothing. Just how bare of rust & paint do you have to get the steel?
I have to restock with some type of tool tomorrow, looking for suggestions.
Thanks!
Lynne
1959newbie is offline   Reply With Quote
Old 06-01-2006, 08:45 PM   #2
Images: 59
Start with a quart each of the POR-15 and topcoat, and a quart each of the Marine Clean and Metal Prep.
After that, order the small cans in kit form, so you don't have a large open can left over. They deliver pretty quick if you don't have a local distributor.
Call them to find out if there is a local vendor.
I found out after a few wire wheels and a few bags of black diamond sandblasting that mineral spirits will get a lot of the paint off. Use lots of rags.
Definitely use two coats. The paint is too expensive to risk having it fail because you didn't follow directions.
Old 06-01-2006, 08:46 PM   #3
Over59's Avatar
Putnam , Connecticut
Images: 37
I also have a 59 overlander I'm doing a shell off on. http://www.airforums.com/forum...9-a-10709.html
I had the frame sand blasted. One heavy coat of POR 15. In fact I think they discourage extra coats. I think I used about 2 quarts. I used black which flows alot more than the aluminum gloss color. Read the POR-15 site for instructions. I have alot of metal ready left so a quart may do you. Good Luck. I hope you made templates of the floor. Also, put the belly pan on before the shell.
Over59 is offline   Reply With Quote
Old 06-01-2006, 09:00 PM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I always understood that POR-15 actually adheres better to rusty metal than perfectly new. It does need to be clean, and loose chunks removed, but not rust-free. I only did our tongue, step & bumper as I didn't have to go through a frame off restoration, but it has held up great for the 5 years since I've done it. Good luck...and remember it stains your skin, so paint neatly! I wore gloves, but I still ended up with a silver handprint on my thigh for over a week.
Shari
Old 06-01-2006, 09:03 PM   #5
Images: 59
Originally Posted by Over59
. . One heavy coat of POR 15. In fact I think they discourage extra coats.
The directions say to apply a minimum of two thin coats, three if a marine or industrial environment.
Old 06-01-2006, 09:14 PM   #6
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Lynne, I sandblasted the frame on my 27' Overlander, so I can't help with that part. But I've read here that you just need to scuff it up and get rid of the rust flakes. The instructions say don't put POR over existing paint.
One Quart of metal ready should be plenty. It took two quarts of POR-15 to do mine and I had a bit left over. (not much, tho) I followed Mark's suggetstion and did two coats. Coat number two goes on a lot easier than coat one.
You only need to top coat anything that will be exposed to sunlight.
If you need help sleeping tonight, take a look at my thread. Skip ahead to about October of last year. There's a better explanation there.
http://www.airforums.com/forum...nte-15132.html
www.nesa.org
Air No. 6427
Old 06-01-2006, 09:19 PM   #7
1959newbie's Avatar
Thanks for the quick responses!
I have one other question on this topic: I'm doing this shell-on, so I'm wondering if anyone has any good tricks for cleaning and painting in the tight areas around the edges?
Lynne
Old 06-01-2006, 09:24 PM   #8
Got gandkids?
Wellllll, I'm not sure how a '59 is put together, but the '73 is made in such a way that you can GENTLY move the outer walls around to paint. It's in my thread (above). Somebody with '59 experience will have a better idea.
www.nesa.org
Air No. 6427
Old 06-01-2006, 09:26 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
In Case it Isn't Absolutely clear...
POR-15 is designed to paint over rust...
Metal Ready is designed to make POR-15 adhere to metal that is not rusted...
If you wire brush rusty, oxidized steel, you do not need Metal Ready...
If you sand blast, you do need Metal Ready...
Two coats of POR-15 are plenty... More is not necessarily better...
A top coat is necessary only for POR-15 that will be exposed to the damaging UV rays of direct sunlight...
Hence, no top coat required or recommended for those frame members between floor and belly pan.
Have fun trying to get it off your skin!
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 07-01-2006, 10:20 AM   #10
1959newbie's Avatar
POR-15 fumes?
Well, after losing a month due to 1st welder flaking out on me 3 weeks in a row, having to find 2nd welder, and having to make an unscheduled trip to deal with my octogenerian parents, I'm ready to POR-15 the frame tomorrow!
Because it's a holiday weekend, I thought I better find out if I need to go get a respirator today. Those of you who applied it with a brush, how bad are the fumes? I'll be outdoors, obviously, but the shell is still attached to my frame, so things are somewhat enclosed. Also, I'm pretty sensitive to such things.
Will open windows, no floor and an exhaust fan be enough?
Lynne
Old 07-01-2006, 12:18 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Lynne -- Ahh, my favorite part of Texas! I've got family in Blanco, Austin, Alamo Heights (S.A.) and College Station. The Blanco folk are Strayhorns distantly related to Tejas polly-tics.
I have used organic vapor respirators and it is amazing how comfortable they fit and how little you can smell. You must always assure adequate oxygen supply so your windows-open and fan plan sounds good. I do not recall that the Por-15 was so obnoxious that I used the respirator. I definitely used it for the solvent/volatile Rot Doctor!
Local sources? Check out www.homedepot.com, enter respirator in the search field -- two AOSafety products show up -- now just if they have it in your local store. I've honestly seen these in any good woodworking store or paint department. Maybe even an auto supply (paint section). Cheap insurance!
5 meter Langford Nahanni
Old 07-01-2006, 12:46 PM   #12
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Black stuff
Shari
This is true, in my experience. It "likes" rust, but anything loose that you could easily scrape off will keep it from adhering to the frame, so don't get too detailed on removing the rusty surface, but definitely do get off the loose stuff that can flake off. You'll just be doing unnecessary work. Find a long sleeved teeshirt and some long pants that you are willing to throw out! Rubbing POR15 off of your skin with a pumice stone works...but a layer of skin definitely comes off with it...so you're stuck with black paint or something that looks like open sores...better to not "get any on ya".
Fumes aren't too bad if you're not inside a building but if it bothers your lungs, take the extra step and get something to cover your mouth. Can't hurt to be careful.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 07-01-2006, 01:09 PM   #13
New steel tends to have a layer of oil on it and that needs to be removed.
For restoration I don't think you could go wrong preparing a surface to remove loose rust, then treating with Metal Ready. Just the rusty areas develop the phosphate layer IIRC. Then you'd be ready to apply the Por-15. I think the instructions on the can govern recoating within a specified period; otherwise you might have to roughen the surface to give 'tooth' for a second coat to adhere. Remember the Por-15 surface should not be exposed long term to sun without a UV blocking finish.
You don't have to strip previous paint but I'd sure roughen it to provide tooth there too.
Thank you pink' -- I'd thought of going back over this. I fully agree if there is asthma, respiratory problems or history of sensitivity to fumes.
Old 07-01-2006, 03:28 PM   #14
1976 25' Caravanner
Campton , New Hampshire
Can anyone tell me what Por-15 instructions say about previously painted surfaces ? Thanks
ticki2 is offline   Reply With Quote
Argosy Minuet 22' and 24' (1979?) overlander64 All Argosy Trailers 67 10-31-2007 09:17 AM
Airstream: The Rebirth of the Silver Bullet thenewkid64 Airstream "In the News" 22 03-16-2005 12:24 PM
What does stick to aluminum? malconium Interior Restoration Forum 21 08-26-2004 05:20 AM
Tow Vehicle hrnicho Tow Vehicles 22 10-23-2002 12:20 PM
