POR-15 Glisten PC
Apparently this product was discussed about 8 months ago (can't find the thread) and appears to be the ultimate answer to sealing and maintaining a polish job. It is a 2 part system used
mostly on aluminum wheels. Has anyone tested this product?
Here's the info on it:
I have not used this specific paint you are refering to but have just done the tongue and underside of my Airstream with Por 15. It is so incredibly hard it is almost like metal. When painted on with a brush, it gets smooth, like it was done with a gun. I was so impressed, I did the wheels on another trailer with the silver. They look like mag wheels. I think their paints are worth the extra price. They are excellent to get on the phone if you need more technical info.
Richard
Based on the manufacturer's cover rates it would take about 1 gal/coat for a 22' trailer.they recommend 2 coat coverage minimum- so that calcs. out to approx.
$400 ($155/gal. x2, + wash + shipping).
I am considering calling POR to ask if they will front me the material to do a product test report on vintage Airstreams.
Just wanted to see if anyone else has used it first.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
If what I've heard about the black POR-15 is right, you'd better make sure the skin is perfect before you put this on, because you will NEVER get it off.
If you got someone to spray it, that would be pretty cool. The black stuff is used extensively by the classic auto restoration folks, and they swear by it.
I don't know about the Glisten...but if it's anything like the silver POR-15, I wouldn't do it on the whole trailer! POR-15 is a resin-like paint, it dries super hard with a glass or metal-like finish. I used it on our bumper, step and tongue, it thickens and cures like resin as it's drying. I can't imagine how you would cover a large surface (like your whole trailer) before the consistency starts to thicken...even if it is sprayed. I could see it for a small item like a wheel, tongue, bumper, etc...but the whole trailer?
Even though it is a super-tough finish, it does still chip if hit or abraded. The catch that holds our step in place has already damaged it.
And if you don't like it after it's done or after it starts to chip, how do you remove it? And we all thought the original clearcoat was a b*%@# to remove!?
I called POR and spoke to their tech. rep. who really believes Glisten PC will work well on AS's . I was happy to find out the coverage rates are more generous than their rust products - 3 coat coverage would take about 1 1/2 gals.
He emphasized that it was all about preparation and getting any oxidation or compounds off the skin.
If I decide to try the product I will report on the results, but I am still at least a few weeks away from getting the polish complete.
Murray
AIR #189
I'm dying to find out your results with this stuff. My 22' Safari is getting ready for another polish, and I will use this stuff if it works. Thanks for the thread.
Why don't we, as a group, get on A/S case about using something like this if it solves all of our problems..
Let them know that "COST' be damn'd...it the long term results that "we want"..`!~
What do you say?
I have talked to my local POR-15 dealer who told me that he wouldn't use this stuff on the trailer. He said he rarely even recommends it for wood. I've also been told that POR-15 suggests that you heat the metal to guarantee that there is no moisture on the metal. My dealer said that if I did decide to use it, not to bitch to him about it if I wasn't happy... because he said I'll really be unhappy if I try to take it off. I use POR-15 religiously on frame and inside body panels on vehicles I've restored.
The statement about moisture is true..But, I take issue with you about the statement of heating the metal
Note this:
AP120 - GLISTEN PC Prep
Designed exclusively for use with our great GLISTEN PCTM clearcoat, AP-120 prep guarantees perfect adhesion of GLISTEN PC to any metal surface, especially chrome or polished aluminum, where good adhesion is often difficult to achieve. AP-120 is non-flammable with no noxious fumes. Wear rubber or latex gloves when using.
Nowhere does it say a word about Heating the surface If you can prove otherwise, I'd like to see it in print from the manufacture. "Not from a friend who says, a friend told him that someone said"..
I have had a conversation earlier with the head office tech rep. from POR and he says they are re-writing the application spec. sheet on Glisten. No release date yet.
He has had alot of experience with the product in Australia, where the U.V. levels are higher and sun exposure is 320-340 days /year. He thinks it would work well on A/S's. If you read the description on their website, it states that it draws moisture from the atmosphere during the curing stage to achieve it's hardness. I did not see anywhere, nor did he mention heating the metal prior to application.
Unless someone finds something better soon, I still intend to test the product - hopefully with POR 's support so we can answre this question once and for all.
Murray
AIR #189
