Old 05-14-2010, 01:10 PM   #1
Boulder City , Nevada
Question plastikote
I have a 1973 Airstream that I'm replacing the plastikote on the roof sections, I purchased the Remove All 220 and the Plastikote but I have misplaced the instructions on how the apply the Plastikote. Does anyone have the application instructions that they could email me? I remember that they were fairly detailed as regards to temperature.
bcmoore is offline   Reply With Quote
Old 05-14-2010, 03:31 PM   #2
The original clearcoat or plasticoat has a life span of about 5 years, and then becomes dead paint.
You would be wise to recoat the entire trailer, not just the roof.
The present clearcoat is available as a 2 part mix.
Spraying it on at the lowest air pressure your gun will handle, is the best way.
Old 05-26-2010, 07:42 AM   #3
Hi Andy, thanks for the quick response. I was out of down for a week and I replied to your message on Saturday, but I don't think it ever posted because I haven't seen it yet. So, hopefully this time my reply will work.
I do plan on recoating the whole trailer, but I wanted to start with a small inconspicuous area first because I have never done this before and if I mess it up no one can see it.
You said that the Plasticote was a two part mix, I assume you are talking about the Solvent Blend and the 367-HC3-0750 Clear Plastikote? I do have one page of the application instructions that include the mixture amounts and step 1, of the 4 steps for applying the Plasticote, but I a little confused on the mixture amounts:
[I]367-hc-27-0750 Clear-5lbs., EB-Acetate-.69 0z, Solvent Blend-2lbs., Smoothie-14 grams.[I]
I assume that the gallon of Plasticote weighs 5 lbs. and the smaller container of solvent weights 2 lbs. and I mix the 2 container together. Do I need to add Acetate and is there a difference EB-Acetate and just regular Acetate? And what the heck is "Smoothie"?
How soon after I mix up everything do I need to apply it? Is one coat enough or do I apply a light coat first then go back over it, after the first one sets-up a little?
Thanks for all your help.
Bryan
PlastiKote="Engine Enamel"? Sav'h Steve Clearcoat, Exterior Paint & Trim 6 03-07-2009 09:28 AM
