Hi,
Have seen & read the earlier posts about repairing "spots" w/ the clearcoat spray that AS dealers sell.
Which is better; the AS spray, or Plasticoat?
Where is Plasticoat available?
Have a few spots or areas that need some attention.
AS dealers sell spray cans of clearcoat, for bigger sizes you will probably have to contact a AS repair facility/dealer, comes in gallon size. I have instructions if you need them let me know and I will email them to you.
When plasticoat peels off, it has lost it's ability to bond to the metal. The reason is that the plasticoat is dead, therefore it becomes very brittle.
When the touch up plasticoat is used on those spots, it will usually crinkle the edges of the remaining plasticoat.
Unfortunately, the bottom line is that patching or spot painting with plasticoat will not renew the old aged out material.
Patches are exactly that and will usually, very clearly, show. But it is a good way to protect that area from oxidizing, until a complete refinish can done. Painting over any aged out paint, will not resurrect it.
thanks Andy. Good advice as usual. I have some really small spots on the roof where bird droppings I guess, got the coat to wear off. The former owner was not as consiencious as I am when it comes to cleaning that "crap" off. I also keep a very good wax coat on mine which this past year had kept it shiny and hopefully protected somewhat from the elements. Wish I had a big garage!!
For about $150 your wish can come true. It's at Costco. And it's a tent. 20' long 12' wide and 10' high. I have extended the height on mine be using 2" PVC pipe on the legs. It's not the most perment solution (I replace mine about every year) and it is only 20' long so one end of my trailer sticks out. However, it is cheaper than $15000 and goes up lots faster than a garage. With no permits!
>>>>>>>>>>>>Action
1966 Mercury Park Lane 4 DR Breezeway 410 4V, C-6, 2.80 - towing a - 1966 Overlander International Twin Bed
1996 Lincoln Mark VIII Diamond Anniversary 4.6L (275hp), 4R70W - 1990 Ford E 150 5.7L, AOD, 3.73 ____________________________________
Phoenix ~ Yeah it's hot however it's a dry heat!
