Old 02-19-2009, 11:42 AM   #1
Gator1
Gator1's Avatar
2006 25' Safari
San Antonio , Texas
Pine Sap Removal from Plasticoat
How can I safely remove dried on pine sap without damaging the plasticoat?
Jim Gompper
WBCCI #5228
2006 25' Safari FB
Gator1 is offline   Reply With Quote
Old 02-19-2009, 01:20 PM   #2
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
Jim,
I would soak a rag with something like DE-SOLV-IT, GOO GONE, Tar Remover, or some similar product and place it on the affected area and let it soften the pine sap. It should get soft enough to rub off.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 02-19-2009, 01:23 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
My first order of operation with tree sap that has not been left on for a long, long time is to get a bucket with warm water, not scalding hot, but fairly warm. I soak a very soft cloth in the warm water and slowly remove the sap. Sometimes I use what I use to wash the Airstream (Armor All Car Wash) with warm water.
Of course for really, really old sap that has been stuck to the spot for years, I have no idea, I never let it get that far.
A good coating of wax (or Walbernize) prior to a sap condition also assists in the removal process of sap as the sap never really gets to the surface.
Old 02-19-2009, 01:24 PM   #4
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
You might try diluted Simple Green and rinse well.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 02-19-2009, 04:48 PM   #5
Kevin245's Avatar
Not sure if this has been discussed, but we use to use good old fashion rubbing alcohol on our vintage cars. It will dissolve the hard stuff. I don't have any experience using it on an AS, and have no idea what effect it would have on the clearcoat.
We used an old diaper, spot soaked with the alcohol and light pressure.
Best of Luck,
Kevin
Eleanor Roosevelt
Old 02-19-2009, 05:02 PM   #6
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
This has been discussed before. Use Wesson Oil. The amino acids in the vegatable oil will dissolve to sap. Just apply and rub with a soft cloth.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 02-19-2009, 06:07 PM   #7
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Turpentine is the natural solvent, but not everyone has anymore due to latex paints.
Skin so soft has been my dissolving wonder for glue leftover when removing foam double sided tape, but be careful if left too long it will dissolve some plastics.
Dave
LY 30 MH 2000
Old 08-07-2009, 10:27 AM   #8
1984 31' Sovereign
Randolph , Maine
I'm new, so don't listen to me, but I just got a name for something fairly new somewhere on this Forum about a product named RejeX. They claim, if you use this in lieu of wax products, you won't have sap problems, anymore, as well as other stuff trying to adhere to the aluminum. Good Sam has given it's Seal of Approval, if you trust that. I'm going to buy a bottle, and try it. You can buy direct at rejex.com, or eBay Motors sells it both around $20 for 16 oz. Happy Rubbing!
Cushnoc is offline   Reply With Quote
Old 08-07-2009, 11:29 AM   #9
sander17's Avatar
1996 28' Excella
Okemos , Michigan
Images: 42
Watch out for alcohol!
Best of Luck,
Kevin
My experience with the removal of peeling Swoopy Graphics from our '96 is that both ethanol and isopropyl damage plasticoat. What worked on the Swoopy adhesive was WD-40 and elbow grease.
Good luck.
Dave
Okemos, MI
T.V.:'05 Dodge Ram 2500 4x4 Quad Cab Cummins
AIR#2276
sander17 is offline   Reply With Quote
Old 08-07-2009, 11:30 AM   #10
1989 25' Excella
Keystone Heights , Florida
Try putting a ice cube on it until its cold enough to pop off with your thumb nail.
an auto body man says this is his method. haven't tried it. sounds a little far fetched but worth a try. I live in florida and pine tar is a problem
Ben
Bogey32 is offline   Reply With Quote
Tree sap removal?? wyhjr Cleaning, Stripping & Polishing 32 03-05-2017 12:13 PM
Doh! Pine sap leads to light scratching! TennisMan Cleaning, Stripping & Polishing 5 09-05-2008 07:34 AM
Pine Island KOA, FL...anyone? squrlgurl On The Road... 4 01-27-2007 04:07 PM
Have top half pine sap problem ernesto ca Cleaning, Stripping & Polishing 3 09-23-2006 07:00 AM
Remove Pine Sap from Zip Dee Sav'h Steve Awnings 2 08-05-2003 05:05 PM
