Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 03-17-2002, 12:01 AM   #1
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Painting the "tounge" of a trailer...
I need to repaint the tounge of my trailer. I would like to paint it with silver colored paint. What is the best paint to use? I would also like to repaint my Reese weight distribution hitch silver. I take it I can use the same paint?
Thanks in advance! Andy
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 03-17-2002, 11:27 AM   #2
83Excella
83Excella's Avatar
Profile:
And if you have a later model with the metallic blue I have the paint code for that if anyone wants just let me know I will find it and post.
John
83Excella is offline   Reply With Quote
Old 03-17-2002, 11:35 AM   #3
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I found a nice silver/aluminum paint at Walmart- used it to paint some spots on mine, underneath but showing...it looks great shiny, and it covered well. Also has a rust inhibitor. No I did not paint anything that was aluminum already.
ALANSD is online now   Reply With Quote
Old 03-17-2002, 12:36 PM   #4
Andy R
Administrator
Andy R's Avatar
Dallas , Texas
Images: 13
Do you have any more info about the Walmart paint you used? Name, brand, etc...
You gotta love Walmart!
Old 03-17-2002, 01:18 PM   #5
66TradeWind
66TradeWind's Avatar
Profile:
Images: 22
Por-15
I have not used it personally yet but have heard from others that por-15 is a great rust inhibitor. You must top coat if exposed to sun because uv will deteriorate it. Their website is here...POR-15
Terry O'Neill
Calgary, Alberta, Canada
WBCCI 4786
VAC
http://pages.sprint.ca/Streamsite/main.html
66TradeWind is offline   Reply With Quote
Old 03-18-2002, 10:53 AM   #6
Charcigar
Charcigar's Avatar
Profile:  1967 22' Safari
Coquitlam , Beautiful BC
Por-15
This was the product I was going to use for my tongue.Was not aware it would break down if exposed to UV rays.
What sort of top-coat is required?
Charcigar is offline   Reply With Quote
Old 03-18-2002, 12:34 PM   #7
ALANSD
The paint from Wal Mart was a rustoleum product, Shiny Aluminum
or something like that (i am out at the moment). They stocked quite a few paints like that, and when I checked Home Depot had a good selection as well. That Por-15 looks like great stuff, just not as readily available.
WalMart also had the rust stop primer- the one that converts rust to metal, so you can paint over (after you chip off the loose stuff)
Old 03-18-2002, 06:22 PM   #8
66TradeWind
Profile:
Images: 22
RE: POR-15 Topcoat
POR-15 have paint to topcoat with. Click link to go to their website and have a look. Pricey stuff but worth it if it lasts. CLICK HERE
Terry O'Neill
WBCCI 4786
VAC
Old 03-19-2002, 11:52 AM   #9
ALANSD
I checked my aluminum paint it is Duplicolor Hi Heat Aluminum. It was 7 or 8 bucks a can at Walmart, but they had it on sale for 1.50 and I bought and used all they had 4 cans. Did my exhaust, and some other areas...it looks shiny and blends well. I use rustoleum rust stop black enamel on the trailer hitch. Did a few coats, waited for dry time between, and a non humid (rare in Atlanta) day.
Old 04-03-2002, 03:05 PM   #10
apple 1
Profile:  1996 30' Excella
Brighton , Michigan
I have used Por15 on several automotive restorations and while expensive it is well worth it, as it does not chip and it does stop rust if you follow there directions. I am unaware of a UV problem as have only used it on frames which when under the car do not see any sunlight. If done once with Por15 you will never have to do it again.
apple 1 is offline   Reply With Quote
Old 04-13-2002, 05:07 PM   #11
Jim W
Jim W's Avatar
Profile:
Glad to hear that POR15 is that good. The storage area at the rear bumper got pretty rusty. I took the bumper off & cleaned out all the rust I could. I than painted it with POR15. That was really thick stuff. It looks good, I hope it last a long time. The POR was silver in color, so it sort of matches.
SF CA area
77/31' Airstream
99/Suburban/454/4.10
#18248
Jim W is offline   Reply With Quote
Old 04-13-2002, 06:58 PM   #12
Charcigar
Charcigar's Avatar
Jim...did you paint the inside of the rear storage compartment or just the exterior?
Did you use a UV protective topcoat as well?
I will be getting to this project(bumper,steps and tongue)shortly myself,so appreciate any feedback.
Old 05-01-2002, 07:53 AM   #13
tenrsingr
tenrsingr's Avatar
Profile:
Jim, what is the best way to go about getting that bumper off? I also have a great deal of rust. I am starting to worry also... I need to do something soon, cause I tried a rust converter a year ago and I dont think it worked so well... Does the whole back area drop down? Is this a one or two person job? Thanks
Steve_in_Savannah
'72 31' International Sovereign
1999 5.4L Ford F150 Lariat Ext. Cab
wife & cat
tenrsingr is offline   Reply With Quote
Old 05-01-2002, 07:56 AM   #14
tenrsingr
tenrsingr's Avatar
Profile:
color scheeme?
John,
You mentioned you had color numbers? What are they? I would like to repaint the Airstream letters (you can see what they look like in the photo area) and the nameplates on the sides. The ones with International on them, they were once red, white, and blue I think. They have been missing on my TT and am replacing them soon. Thanks.
Steve
Steve_in_Savannah
wife & cat
What is your Brake Controller of Choice? overlander64 Brakes & Brake Controllers 71 11-29-2008 09:40 AM
Some towing Q & A for newbies femuse Towing, Tow Vehicles & Hitches 3 08-24-2004 09:05 AM
trailer wiring Cruiser Electrical - Systems, Generators, Batteries & Solar 4 09-02-2003 02:43 PM
Getting Close! kamadeca Our Community 48 02-05-2003 09:56 AM
Trailer Listing To "Street Side" montanaandy Axles 4 06-07-2002 01:15 PM
