Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 07-28-2005, 09:03 PM   #1
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Thumbs up Painting the roof question
I was up on the roof cleaning it and realized it’s time to be painted. In the prep work do you scrub the adhesive that seals the skylights and vents clean and paint around it or over it. Or should the adhesive be removed and replaced. If I should remove the adhesive do you paint and then apply the adhesive on top of the paint or not. The adhesive looks like it is showing it’s age going on 4 years since manufacturer but does not leak, yet.
Pointers anyone?
Tinsel Loaf is offline   Reply With Quote
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 01:37 AM
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 07:40 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 06:29 PM
Roof coating FrankR Roof 4 07-22-2002 02:56 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 02:35 PM
