Old 11-22-2006, 02:42 PM   #1
1984 31' Sovereign
Newberry , Michigan
fishook
I am rebuilding a 1984 sovereign, there is a lot of rust on the fram, after i clean to the metal what is good to put on it before i paint the fram?.
Cam Chisholm
C. Chisholm is offline   Reply With Quote
Old 11-22-2006, 05:49 PM   #2
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Nothing..........just use POR-15 2 coats and your good to go.
Wear a good respirator.
'77 Sovereign Intl 31' CB
Old 11-22-2006, 06:18 PM   #3
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i sprayed my 18 footer frame with epoxy... but that might have been a little overkill. i wouldn't rattle-can it, though. i hear good things about POR, too.
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 11-22-2006, 07:18 PM   #4
Mom scared by aluminum
dmaiden's Avatar
Phoenix , Arizona
I'm using a rustoleum product. I think it's called Rust Restore or something like that. I just did the front 2/3. Ground it down good with a wire brush on an angle grinder and came in looking like a racoon. Hope it works, but I had pretty minimal surface rust.
Dave and Joanne
1963 Flying Cloud
2005 Silverado 4x4 3/4 Ton
dmaiden is offline   Reply With Quote
Old 11-22-2006, 08:14 PM   #5
soldiermedic's Avatar
Florissant , USA
The shop that is building me a new frame suggested a spray zinc coating that would last for at least 30 years. I dont know much about it, but it must work well. Total cost was 2 gallons for $34.00. Anyone heard of such stuff?
soldiermedic is offline   Reply With Quote
Old 11-22-2006, 08:50 PM   #6
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
I think to get the results you're looking for it has to be HOT dipped.
Those guys are talking about spray a paint----go with the POR-15, it's proven cheap and used in the automotive restoration biz on million $ cars.
Old 11-22-2006, 09:01 PM   #7
Florissant , USA
Is POR 15 available everywhere, or is it online ordering?
Old 11-22-2006, 09:15 PM   #8
Images: 59
Call 800 726-0459, they wil tell you if there is a retailer in your area.
Old 11-22-2006, 09:17 PM   #9
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I get mine on-line from the factory. Google POR15. Michael
ArtStream is offline   Reply With Quote
Old 11-22-2006, 09:20 PM   #10
Florissant , USA
Since my frame will be new steel, will the shop have to etch the metal before coating?
Old 11-22-2006, 09:26 PM   #11
Images: 59
Yes. I had several areas where the POR-15 peeled off new steel, even after using the Marine Clean and the Metal Ready.
If I was starting with a new frame, I would use something else. POR-15 is GREAT on rusty metal. Not so great on unrusty cold rolled steel.
Old 11-23-2006, 04:14 AM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Strange that that happened.
METAL-READYTM provides the best adhesion for POR-15 on any surface, including aluminum and shiny polished metal surfaces. Our simple process gently etches metal, creating an ideal anchor pattern for coatings such as POR-15, while simultaneously leaving a zinc phosphate coating to insure chemical bonding of paint and steel. Avoid other preps that may leave harmful residues which prevent proper adhesion. After thoroughly degreasing your work piece, apply environmentally safe METAL-READYTM to both neutralize any rust and etch any clean bare metal. This will allow better adhesion of POR-15 or any other paint. METAL-READYTM is not caustic, corrosive, toxic or flammable.
Old 11-23-2006, 06:24 AM   #13
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
Cold-galvanizing spray paint chips very easily - although the lawn mower chips and dings around the bases of my 2" clothesline poles I primed with it are just now beginning to rust after six years of exposure. If you do go w/ spray zinc anywhere it should be two thin coats and then has to be well sealed with two or more coats of a hard chip resistant top coat. After using POR-15 and seeing the great results - rock hard, self-leveling and good coverage, I'll use it on mobile projects and keep the zinc-rich primers for things without wheels.
Old 11-23-2006, 07:29 AM   #14
Images: 59
Thanks. Next time I will have someone read that part for me.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 06:43 AM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 03:32 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
