Old 11-23-2006, 07:39 AM   #15
1988 32' Excella
Westminster , Maryland
Rust Bullet rust inhibitor coating and its patented new technology beats POR 15, Rustoleum and other market leaders in independent laboratory testing. Rust Bullet is guaranteed to stop rust and provide rust prevention for 10 years. Check out this Web site http://rustbullet.com/
MikeSandyZ is offline   Reply With Quote
Old 11-23-2006, 08:28 AM   #16
soldiermedic's Avatar
Florissant , USA
I know all of these are good for painting over rust, but I won't have that issue. POR may take alot of prep time for the shop which will add time, especially if it requirs a degreasing stage, then an etching stage, and finally multiple coats of POR. I may just want to find something that can go directly on, but this may sacrifice quality in the final product.
soldiermedic is offline   Reply With Quote
Old 11-23-2006, 09:45 AM   #17
Images: 59
You might have the shop try to get this:
http://www.tnemec.com/product/overview/?p=45
Requires only commercial blast cleaning of the surface.
Otherwise, any bodyshop should be able to fix you up with a good quality primer for new welded steel.
Old 12-16-2006, 09:06 AM   #18
Baton Rouge , Louisiana
Images: 42
Bedliner material
Guys,
Just my two cents but I am going with a gloss black product called Durabak (you can find it on ebay or at the company website). It's a high grade bedliner product and the only prep is a thorough sanding followed by a Xylene wipe down. It rolls or sprays on. I saw it on an AS in a park in Colorado this year and it looked great! I intend to use it to mask the very front of my Sovereign too for rock protection.
-Don
cobra93 is offline   Reply With Quote
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
year frame size reduced yukonsilver Airstream History 1 04-19-2004 12:53 PM
Cracked door frame 77caravaner Doors & Locks 5 10-11-2002 06:43 AM
Painting your Airstream jkleven Clearcoat, Exterior Paint & Trim 25 07-18-2002 03:32 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
