Old 06-02-2016, 05:08 PM   #1
clamb's Avatar
2002 25' Classic
Portland , Oregon
Painting over rust- Chassis Saver review
As my '02 AS was showing a fair amount of rust on the A frame, and especially in the storage box, I decided to deal with it by painting everything. My local auto parts store recommended Chassis Saver, which I went with, and I am really pleased by going this route. It is a high gloss black- I was hoping to stick with the AS gray color, and I still could, but I like the look. You can paint over it, but need to de-gloss it first.
It is not cheap, at $40/quart. You need to do a minimal amount of prep- wire brush the rust and sand the existing paint to remove gloss. No primer needed whatsoever- you can paint this product over rust, bare metal, or existing paint. You do need to wear gloves, and have plenty of ventilation- this stuff is nasty! I have some on my hands and have to wait a few weeks for skin cells to reproduce.
After full cure, it ends up rock hard- I can't make a mark on it with fingernails. I painted a small area to try it out, and the next day, it was all I could do to pry the lid off the can without destroying it.
clamb is offline   Reply With Quote
Old 06-02-2016, 05:21 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Sounds interesting. Pics??
Old 06-02-2016, 06:56 PM   #3
clamb's Avatar
2002 25' Classic
Portland , Oregon
Here's a few pics. I wasn't too fussy on appearance
ID:	263743   Click image for larger version
Old 06-02-2016, 07:02 PM   #4
W , New England
Thanks. Very interesting!!
Old 06-02-2016, 07:48 PM   #5
clamb's Avatar
2002 25' Classic
Portland , Oregon
I should note that these pictures were taken after it rained- some water beads
Old 06-03-2016, 06:03 PM   #6
2003 31' Classic
Terra Alta , West Virginia
Is it similar to por 15? I've heard good things about the chassis saver.
Dave
wvstreamer is offline   Reply With Quote
Old 06-03-2016, 06:10 PM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I always have used Chassis Saver instead of POR. Same stuff....readily available and less expensive (a bit).
Old 06-04-2016, 03:06 AM   #8
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Thank you for that recommendation.
Old 06-04-2016, 04:38 AM   #9
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you! I did not know this existed.
I'm going to see if it is available here.
Dingo Girl is offline   Reply With Quote
Old 06-04-2016, 06:18 AM   #10
Vycan's Avatar
1994 36' Classic 36 Diesel
Manhattan , Kansas
It comes in aluminum too!
1994 36' Classic Diesel Pusher
Vycan is offline   Reply With Quote
Old 06-04-2016, 07:11 AM   #11
Burnside Bob's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mt Angel , Oregon
This sounds like a great product. Was one quart enough to do your "A" frame and the rear bumper door?
I repainted the "A" frame on our 31' several times, power wire wheeling down to bare metal , primering with rust inhibiting primer, followed by two coats of silver colored rustoleum. Five years later the "A" frame would have rusted here and there requiring a "redo".
Our 2009 could use a repaint and I can see the previous owner has repainted the "A" frame at least once already. I wasn't satisfied with my previous results so am looking for a different product.
Thanks for sharing a great tip!
Best, Burnside
"To err is human, to air is devine."
Burnside Bob is offline   Reply With Quote
Old 06-04-2016, 08:01 AM   #12
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Also available in #98 light gray. Qt. of any color $31.66 plus $6.99 shipping anywhere USA.
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 06-04-2016, 08:04 AM   #13
clamb's Avatar
2002 25' Classic
Portland , Oregon
I didn't even use 1/2 quart for the A frame (two coats). I should also point out that I slit some garden hose to slip over the bottom of the propane tanks, and lined the storage box with some anti-fatigue mat from Home Depot to prevent any future damage to the paint.
Old 06-04-2016, 08:41 AM   #14
1981 31' Excella II
New Market , Alabama
Does it chalk after being exposed to UV like the POR15 does?
Perry
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Stopping Chassis Rust on 2009 AS tmarquis Repairing/Replacing Floor &/or Frame 2 04-02-2011 09:53 PM
Controversy over the frame rust. by "Boatdoc" boatdoc Repairing/Replacing Floor &/or Frame 36 11-17-2006 10:53 AM
Airstream Screen Saver jcanavera Off Topic Forum 24 09-25-2006 11:05 AM
Problem report/Tank Saver Flushing Tool wyhjr 2001 Safari 11 09-21-2003 08:24 AM
