Old 08-02-2010, 02:31 PM   #1
1988 34' Excella
Orlando , Florida
Painted White Tops
In several of the numerous photos posted on the forum I have seen painted white tops on beautiful highly polished Airstreams. Was the painted white top an Airstream option at one time or is this just an owner decision to paint? Is the paint an effort to seal leaks or reduce heat gain inside the unit? I have found no threads that discussed this.
Mike Eagle is offline   Reply With Quote
Old 08-02-2010, 02:45 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
it is an Airstream thing
It was a factory application. I do not know when it started. My 95 Sovereign had it. I am putting it on my 56 Cloud...previous owner had it done about 15 years ago. While I think the original idea was to reflect heat (what I want it for) some folks use thick rubberized coatings...I guess in the hope to prevent leaks. I am using Ceramaflex white. use search function on ceramaflex and you will get some discussions.
Old 08-03-2010, 05:40 AM   #3
1988 34' Excella
Orlando , Florida
Painted White Top
Thanks for the prompt reply Melody Ranch. Glad to hear it is an Airstrem item. I tried to search the product you plan to use, "ceramaflex", on the forum but I have never get any results here. (must be doing something wrong). I did a search on Google and got some interesting results. One is an industrial product applied in several steps by trained contractors on roofs for heat reduction. Second, was a thin set product used to install ceramic floor tile and the third was a white mastic used to install ceramic wall tile. Is the product you plan to use purchased locally?
Old 08-03-2010, 06:55 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ceramiflex (only available in 5 gal) is made by a company called Sealoflex. You don't need special skill of equipment. They also make Reflectowhite (available in 1 gal) which is another option. Some people have put it on without primer, but a tech at the company recommended using their metal etching acid primer. To seal the roof the company recommends a final coat of Reflectowhite. It is not a specific trailer product, but a specialty architectural paint. It does seem to keep my trailer cooler.
If the polished Airstreams you refer to are vintage, it was not factory. It now is on new Airstreams.
Old 08-04-2010, 08:11 AM   #5
1988 34' Excella
Orlando , Florida
Painted White Top
Thanks Lumatic, that clears up everything.
Corian Counter Tops Rod Pease Cabinets, Counter Tops & Furnishings 27 04-22-2015 04:01 PM
Granite Counter Tops Cstar Cabinets, Counter Tops & Furnishings 20 04-04-2011 11:08 PM
Airstream Roof Tops KANEHILL Roof 5 09-24-2007 09:21 AM
76 beauty bathroom tops richw56 Member Introductions 0 07-08-2006 10:50 AM
Corian Counter tops smily Cabinets, Counter Tops & Furnishings 4 11-27-2002 07:31 AM
