Old 02-28-2008, 05:30 PM   #1
1976 31' Sovereign
Dallas , Texas
Unhappy Painted stripe on '76 is peeling
I have a blue stripe on the side of my trailer which is peeling off in places. When I recently power-washed it, the water pressure peeled off a few more flakes. Is this something I can/should repair or am I better off finding someone who can do the job? What is involved?
RonP is offline   Reply With Quote
Old 02-28-2008, 05:37 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forums!
The Excella stripe is usually a decal, but may be painted on non-Excella models. Pressure washing is generally considered a no-no, because the high pressure water may force open the seams in the body, causing leaks.
If it's painted, you may be able to touch up the spots with a brush or spray can, but it won't exactly match what's there.
Old 02-28-2008, 06:14 PM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
I have a 1976 Sovereign and the blue stripe on mine is a vinyl insert that fits into that channel on each side and then a larger insert at the belly. It's possible that a pervious owner got tired of putting in the vinyl and painted inside that channel. Post some pictures of yours so we can see what you're dealing with. I agree about not using the power washer. Also, you can order the vinyl insert from an Airstream dealer or Inland RV. It's not expensive and very, very easy to insert. You can see the channel on mine; however, I've removed the vinyl insert and am installing new as soon as a warm day comes along.
ID:	55237   Click image for larger version
juel is offline   Reply With Quote
Old 02-29-2008, 05:15 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
One option is to remove the decal and replace it with a wide blue reflective stripe through a company catering to law enforcement like Galls. I'm sure that would be expensive but you sure would be seen for miles.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 02-29-2008, 05:22 PM   #5
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
You can also by it from a sign making shop. I inquired about some last year for our Overlander. They will cut it to whatever width you need.
On ours, John ended up just removing all the old and painting a new stripe with a small brush. It took him a while but turned out very nice.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Painted Airstream NicheVintage Cleaning, Stripping & Polishing 13 02-23-2013 04:26 PM
Shower wall covering peeling ?? Solution ?? polarlyse Sinks, Showers & Toilets 6 02-06-2012 08:08 AM
Door Handle Peeling Jfuller678 Doors & Locks 6 12-17-2011 09:24 AM
Black letters peeling cutterbug Clearcoat, Exterior Paint & Trim 20 06-14-2011 08:31 AM
Living with peeling clear coat? timmaah Clearcoat, Exterior Paint & Trim 14 04-26-2011 09:20 PM
