Old 04-16-2011, 10:19 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, now I am working on the hitch head. Today I took it all apart, cleaned it and started to re-paint it. After the paint cures, I will remove the tape, grease it, and put it back together. I will torque my pivot [spring bar sockets] bolts to 75 lbs and it will be ready for our next trip. ?????
ID:	127171   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 04-16-2011, 10:28 PM   #16
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Looks good!
4RXLA is offline   Reply With Quote
Old 04-17-2011, 06:20 AM   #17
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
You guys have me motivated to repaint our 2004 after our current trip ends. Thanks to each of you for posting all this information. Another project for my "DO LIST".
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 04-17-2011, 06:37 AM   #18
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
I have had some success with spraying a couple coats of clear coat (from a can) over the finished color coat. Seems to help keep the nicks and scrapes down a little.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 04-21-2011, 05:53 PM   #19
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
Hi All:
Though new to "stream'n" my years of maintaining steel yachts may help.
Firstly though, this is not the inexpensive way to go but you will not have to do it again for years.
In a perfect world with some lose pocket change and time...you must (after building a tent to contain the work so you don't get rust on the unit)
a) Strip all old paint.....you'll be surprised what is lurking under what looks ok.
b) grind to shinny steel....do not wire brush as you'll "introduce" metals of dissimilar quality which may make things worse. Use sandpaper wheels.
Optionally you can sand blast and skip everything to step (d).
c) wash thoroughly and wipe dry quick.
d) brush on oxalic acid (diluted 10/1 please)and allow to penetrate any "pin holes" for an hour.
e) repeat step (c)
f) apply two coats of "Rustlock" primer by "Pettit"..light abrasion between coats
This is a toxic paint as it etches the surface...wear respirator AND ventilate.
d) paint with your choice of poly-urithane paint system/color.
e) clear coating is a good thing also.
"Rustlock" is silver/grey in color and you could just do 3 coats and leave it....it'll hold up fine. I've seen dock bollards painted with it!!
This is the first area I'm going to do when "Tinbad" gets in the barn.
Don't get specks of rust on the unit....you won't see them till they oxidize and from then on out it gets ugly. Build an airtight tent AND still wash (not just rinse) the unit after sandblast/grinding....twice....really...no fool'n.
Cheers
Del
Del Gurney is offline   Reply With Quote
Old 04-22-2011, 02:59 PM   #20
Salem , Oregon
Images: 18
Hi, my hitch is now ready; Now I need to plan a trip, even a short one. With my tongue and hitch all prettied up, I'm ready to go.
ID:	127866   Click image for larger version
ID:	127868   Click image for larger version
2005 Safari 25-B
Old 04-22-2011, 04:29 PM   #21
idmtman's Avatar
Worley , Idaho
New decals
Equal-i-zer will send new decals for your hitch for free. Just contact support and they will mail new ones to you. I just replaced mine today.
Idmtman
2006 Safari 28' SE (Sylvia)
75th Anniversary Edition
2010 Toyota Tundra 4x4
TAC: ID-1
idmtman is offline   Reply With Quote
Old 04-22-2011, 06:06 PM   #22
San Diego , California
Airstream Pewter Gray
Bob:
I bought some Airstream touch-up Pewter Gray #360260-100 from C&G a couple of years ago. The color matched perfectly. The only problem was that it never dried. I sanded, primed with Rustoleum gray primer and painted with the Airstream spray. I had it hanging a week in my tool shed in the summer...still very soft and tacky. Somewhere on the forums I read that somebody recommended Plasti-kote #1543 Charcoal Gray metallic. It actually is nice paint, only it is metallic so it has, I guess, more silver in it. (Knowing the Air Forum people, they will say, what's wrong with more silver)? It does look nice but it isn't exactly the same. I think that possibly the paint I got from C & G might have been old. (It wasn't cheap). I wonder if anybody has ordered it from Airstream in Ohio?
I painted my Equalizer with Gloss Rustoleum and it turned out great. (Home Depot).
Randy Bowman
OB Bambi is offline   Reply With Quote
Old 04-22-2011, 06:42 PM   #23
plano , Texas
The easiest way to protect decals while spray painting is to use vasaline. I have used it for years painting lawn mower engines and it works great. Not to mention, the price is right.
-t
tschat is offline   Reply With Quote
Old 04-22-2011, 09:05 PM   #24
Salem , Oregon
Images: 18
Originally Posted by OB Bambi View Post
Bob:
Randy Bowman
Hi, Randy. My paint dried in about an hour, you must have had a bad can. I painted my Equal-i-zer with Rustoleum / semi-gloss.
2005 Safari 25-B
Old 04-22-2011, 09:07 PM   #25
Salem , Oregon
Images: 18
Hi, idmtman. Even though I replaced my spring bar decals with reflector tape, I think I will put some new decals on too.
2005 Safari 25-B
Old 04-30-2011, 12:07 AM   #26
Salem , Oregon
Images: 18
Hi, today I decided to repaint my Guardian G-37 coupler lock. It wasn't looking too bad or too good either, so I painted it black too.
ID:	128653   Click image for larger version
2005 Safari 25-B
Old 05-06-2011, 10:14 PM   #27
Salem , Oregon
Images: 18
Hi, my new Equal-i-zer decals came in the mail yesterday, so today I put them on.
ID:	129219   Click image for larger version
2005 Safari 25-B
Old 05-23-2011, 02:04 PM   #28
LLB21's Avatar
I had the spray paint that didn't dry. C&G told me that Airstream finally recalled all of the cans of paint from January forward. We were all having trouble.
Once the formula was straightened out they replaced it. C&G swapped my can out when they got the new ones in N/C.
Louie
LLB21 is offline   Reply With Quote
Sunburn or spray paint? Tabasco Cleaning, Stripping & Polishing 10 05-24-2012 10:01 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 01:19 PM
Need Tongue Jack - Suggestions? kj78133 Jacks, Stabilizers, Lifting and Leveling 16 02-23-2011 05:55 PM
GT Paint Job IronGiant Upholstery, Blinds, Walls & Interior Finishes 0 01-11-2011 10:17 PM
Tongue weight verses tongue height - level the WD hitch? HowieE Hitches, Couplers & Balls 12 11-17-2007 01:02 PM
