Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-10-2004, 06:45 PM   #1
tinsltootsie
tinsltootsie's Avatar
Profile:
Images: 27
paint for the tongue
We just bought a 74 Overlander which is in decent shape. One of the things we would like to address at this time is the tongue that has some minor rust. Is there a paint that is recommended that would look best with the satin finish on this trailer? (it still has its clearcoat) We can use automotive finish, or a spray can paint. Thanks for any help.
tinsltootsie is offline   Reply With Quote
Old 05-10-2004, 06:49 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We used POR-15...others have used the spray on Rustoleum. I am very happy with the Por-15 and would use it again.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
InsideOut is online now   Reply With Quote
Old 05-10-2004, 07:21 PM   #3
maxandgeorgia
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Hmm...I've been thinking about this too. Our tongue has some rust and the weight distribution bars are rusty too. None of this is deep rust--just unattractive at this point. Ours are black. Should black continue? Are some tongues/bars painted the silvery aluminum color? What's good for this area?
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 05-10-2004, 11:43 PM   #4
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
I just finished painting our A-frame with POR-15 after reading about Shari's good experience. This is the best paint I've ever used. It's wonderful! It goes on so smooth it actually glistens. It also fills in small voids and imperfections giving you a very level surface. I was going to paint it to match the grey on the rest of the belly pan of our '78, but when I got done, I liked the gloss black so much that I decided to leave it black. With the POR-15, you have to topcoat it because it's meant for frames and undercarriages and is not UV resistant. I used Rustoleum gloss black over top of it. The POR makes such a thick coat that it's pretty scratch resistant, too. I'm going ahead and painting all of the exposed frame members under the trailer with it now. Wonderful product!
-Dallas
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 05-11-2004, 12:17 AM   #5
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
One thing I learned the hard way is to remove all of the paint stripper before repainting. Gasoline works well.
I've had good results with Krylon spray cans of primer and paint.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 05-11-2004, 04:22 AM   #6
tinsltootsie
Profile:
Images: 27
Thanks for all the info. The POR-15 looks like the thing we are looking for. I just glanced at info and pictures and will pass it on to my husband. I may have missed this info, but did you spray first with rustoleum, and then use this POR-15? Also, where did you purchase it? I see there is a web site, but did not click on it. (on my way to work) Thanks again for all the helpful info! I'm just lovin' this trailer!
Old 05-11-2004, 07:22 AM   #7
InsideOut
InsideOut's Avatar
1956 22' Safari
Images: 87
No, you apply the POR-15 directly to the surface after cleaning off any loose rust flakes with a wire brush. It attaches to the rust & prevents it from continuing to spread...that's what it's made for. The Rustoleum wouldn't help as a basecoat....it actually would defeat the purpose of using the POR-15.
We found it in stock at an automotive paint supply store but it can also be purchased online. There's a link on my webpage above in my earlier reply that directly links to the POR-15 website where it can be ordered.
Good luck!
Shari
Old 05-11-2004, 07:30 AM   #8
Over59
Over59's Avatar
Profile:  1959 26' Overlander
1968 17' Caravel
Images: 37
Check their web site. They have a system you can use and sell it as a package. I used the sterling silver and it looks real nice.
Let those who can play, let those who cann't rule.
Over59 is offline   Reply With Quote
Old 05-12-2004, 04:36 PM   #9
tinsltootsie
Profile:
Images: 27
I will look at airstream's site as well. We go their polish and some other things to clean with and all seem to work well.
Old 05-13-2004, 07:47 PM   #10
tinsltootsie
Profile:
Images: 27
Couldn't find the tongue paint on airstream/shop site. Any help?
Old 05-27-2004, 11:34 AM   #11
Tom Nugler
Tom Nugler's Avatar
Profile:  1967 20' Globetrotter
McHenry County , Illinois
Thumbs up
Just ran across this thread. Before it started pouing buckets here in northern Illinois I started painting the steel front end parts on my 67 GT with Duplicolor alloy wheel paint. After cleaning up the rust it took two coats to cover and looks pretty good. This is a eurathane type paint, has a high satin shine and it seems most auto parts places carry it.
Good Luck, TOM
Tom Nugler is offline   Reply With Quote
Old 06-05-2004, 06:02 AM   #12
HP9K
HP9K's Avatar
Profile:
I have had good luck with Rustoleum's new "hammered" finish paints. I have used the silver and the charcoal and they both leave a nice finish that does really have the appearance of hammered metal.
HP9K is offline   Reply With Quote
Old 06-05-2004, 02:26 PM   #13
iowaroots
Profile:  2003 30' Classic
Dallas Center/Des Moines , Iowa
Airstream touch up paint.
We just bought some touch up paint. Airstream part #360260-100 Pewter Gray. Got it at http://www.btcamper.com/
iowaroots is offline   Reply With Quote
Old 06-05-2004, 02:37 PM   #14
Tooldlr69
Profile:
If there is rust present on the tongue, then use a terrific product called Hammerite. The product can be placed directly over rust. The coating dries w/ heat hardened glass flakes that interlock to prevent further moisture reaching the substrate causing corrosion and/or rust. It comes in smooth and hammered finishes as well as brush on and spray. I sell it in my hardware store and it is probably easier to find in southern regions.
Tooldlr69 is offline   Reply With Quote
selling useful parts/30amp cord, pex crimper, bath paint Lexxy Parts Archive 2 05-03-2004 12:48 PM
Interior Paint Lone Ranger Upholstery, Blinds, Walls & Interior Finishes 8 05-02-2004 10:34 PM
POR paint inquiry gsymes Clearcoat, Exterior Paint & Trim 8 02-27-2004 06:01 PM
tongue paint B25guy Clearcoat, Exterior Paint & Trim 1 08-28-2003 07:52 AM
Paint for frame and tongue dmac Clearcoat, Exterior Paint & Trim 3 01-15-2003 04:39 PM
