Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 08-24-2002, 03:23 PM   #1
Howard Lefkowitz
Profile:
Paint Repair Primer
I have a number of very small paint bubbles, on my 1990 345LE Motor Home, in both the Red and Grey painted areas. I have the paint and am in the process of cleaning the bad areas. I checked with PPG for a recommended primer and they said to use an epoxy they sell which must be sprayed. The areas are two small for this. Does someone know of an aluminum primer that I can just dab on with a brush? I intend to just brush on the paint. Do I need a primer at all?
Howard Lefkowitz is offline   Reply With Quote
Old 08-25-2002, 11:14 AM   #2
williamhenshall
Profile:
Images: 171
primer..
Heya
If it's a small area I guarantee you could use one of the spray cans of auto metal primer...aluminum is pretty much the same to work with as steel...
If larger Benjamin Moore makes high quality XIM metal primer (I used this on the inside of my 58 Travaler before I painted the top coat
Best
Will
WBCC #8048
1958 18Ft Traveller
Los Angeles CA
williamhenshall is offline   Reply With Quote
Old 08-25-2002, 11:56 AM   #3
Howard Lefkowitz
Profile:
Thanks Will.
Alternate exterior plastic parts repair IPM Bumpers & Bumper Storage 2 01-24-2008 10:46 AM
Exterior paint peeling! Astrodokk Airstream Motorhome Forums 2 08-10-2003 08:18 PM
'92 paint vs. clearcoat fangthorpe Clearcoat, Exterior Paint & Trim 1 06-22-2003 10:23 PM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
