Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 10-18-2005, 10:21 PM   #1
tracker
tracker
tracker's Avatar
Profile:  1969 23' Safari
fort dick , California
paint removal
Can anyone tell me the safest way to remove old faded paint from the exterior of an otherwise nice looking airstream . It looks to be spray paint? thanks.
tracker is offline   Reply With Quote
Old 10-19-2005, 04:28 PM   #2
nickcrowhurst
Profile:
Tracker, the "Aircraft" paint stripper (which I get from Wal-Mart) should do the trick without damaging the skin of the trailer. It will, of course, also remove any factory clearcote from the skin. If you need to remove the paint without touching the clearcote, I would carefuly use the rubbing compound that is used to shine up or renovate spray painted surfaces on, for example, motor vehicles. It is available from your local NAPA or similar store.
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-19-2005, 05:49 PM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
I stripped my Clear Coat with Por Strip, Nice stuff, very little effort!
http://www.por15.com/search.asp
http://www.balrgn.com/Airstream/airs...oject_2004.htm
Good Luck
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Blue paint uwe Clearcoat, Exterior Paint & Trim 16 07-28-2008 05:53 AM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Paint Removal from side of A/S Lexxy Clearcoat, Exterior Paint & Trim 2 08-19-2002 07:03 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Dark grey bottom paint. apple 1 Clearcoat, Exterior Paint & Trim 1 04-07-2002 12:20 PM
