Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-23-2006, 02:48 PM   #1
Angel73's Avatar
Profile:  1975 31' Sovereign
Woodlawn , Tennessee
Images: 65
paint or not to paint roof
We're trying to decided weather or not to paint the roof to help control heat and to help seal the roof better....What do you all think?
The Clark Family
Angel73 is offline   Reply With Quote
Old 05-23-2006, 04:36 PM   #2
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Angel, I painted ours white when I painted the trailer, I am not sure if it helps or not, I think it might. It was a lot easier to do than paint the roof as I rolled the top. You can't see it unless you are at higher area looking down on the trailer. Here are some pictures. Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-23-2006, 05:03 PM   #3
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
looks new!
man, what a nice looking coach! It makes me want to paint my A/S cream-colored, with white roof! Serious question: do argosies reflect heat and stay cooler in summer than airstreams? thanks- tim
tphan is offline   Reply With Quote
Old 05-23-2006, 05:04 PM   #4
Profile:  1977 31' Sovereign
McHenry , Illinois
I have a 77 soveriegn. I painted the roof five years ago. It is pealing a bit so I am going to redo it. We went to the Internationals in Huntsville once and Rapid city twice. No power for air cond. so we sweated. White roof helps some vs production plasticoat that was pealing and dull. I think it helped about 10 degrees on a 100 F day but difficult to actually measure under controlled circumstances. Which of course you can not control. Seen quite a few people from the west and south doing it. I painted from the awning strip to the end of the roof sheet on the other side and did not paint the ends. You hardly notice it when you walk past the trailer.
Old 05-23-2006, 05:27 PM   #5
klevan's Avatar
Profile:  Albuquerque , New Mexico
What's the Best Paint?
I'm convinced that painting the roof white will cut down on solar gain, but I remain unsure of best paint to use and best application process. Suggestions?
Ken Levan
2005 Chevy 2500 HD Duramax/Allison
Formerly WBCCI #8654
klevan is offline   Reply With Quote
Old 05-23-2006, 06:35 PM   #6
Ken.. we used a product called Snow Roof ... available at Ace hardware.. it takes about a gallon to do a 26' trailer... Marvin
Marvin & Annie
1979 Argosy 30
WBCCI 10103
Old 05-23-2006, 06:38 PM   #7
klevan's Avatar
Thanks, Marvin. You used a roller, correct? Standard 1/4 inch nap?
Ken Levan
Old 05-23-2006, 07:25 PM   #8
Angel73's Avatar
Images: 65
well
The main reason we was thinking about it is that hubby doesn't want to try to polishes the top now that we stripped it.Cause he doesn't want to dent the roof....Plus we normal use just batteries and it does get hot
The Clark Family
Old 05-23-2006, 08:07 PM   #9
Ken, Yes, did it with a roller, 3 coats. Two would have been enough but the rest would have went bad. It seals the seams and rivets good too.
Marvin & Annie
1979 Argosy 30
WBCCI 10103
Old 05-23-2006, 08:50 PM   #10
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Look into products by DICOR. I use their stuff to re-coat EPDM rubber roofs of SOB's that are about to disintegrate. It bonds really well with the existing rubber and might do so with the aluminum as well. Give them a call.
You might also try POR-15. Folks on this forum swear by their stuff as being very durable. I would also seriously consider a self-etching primer applied to theh bare aluminum before applying any type of paint. It will make the paiint last much longer.
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
lewster is online now   Reply With Quote
Old 05-23-2006, 09:08 PM   #11
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
I have restored 2 sailboats in recent years and getting ready to do the last on again as Katrina totaled the boat. Don’t tell me you are sorry as the insurance paid me out and gave the boat back to me. I did want to suggest a paint that I use often and holds up very well in the marine environment and on decks. Look into Interlux Brightside Polyurethane. Brightside lays out like glass.http://www.yachtpaint.com/usa/
Select Paint finishes on the left side.
I also remember that painting the top white lowers the temp by 7 degreees.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174,WBCCI 5131
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Check the weather at my home
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KLANEWOR12
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 05-23-2006, 09:26 PM   #12
Profile:  1960 24' Tradewind
santa barbara , California
Hello everyone,
I know inland andy had done some good tests with aluminum panel samples
painting them three different colors and the for one was plain aluminum .I don't know the link,but someone here might or contact andy himself at inland rv.The surprise was that the aluminum plain sample was cooler than even the white one by a small but surprising amount .The plain sample just reflected the heat away better the test revealed .I would check into that before I would paint the roof of your airstream .I myself thought the white would be cooler .
Scott
scottanlily is offline   Reply With Quote
Old 05-23-2006, 09:40 PM   #13
klevan's Avatar
Thanks, Lew. I'll research DICOR. As for POR-15, I've had extensive, exhaustive, expensive experience with POR-15 in my restoration of Willys CJ2A #75863. http://spongedude.info/cgi-bin/willy...on=view&id=272
I'm not a fan of POR-15 nor would I recommend it. Besides, it will not hold up to UV. Even limited exposure to sunlight destroys it.
Jim Clark, thank for your suggestion re Interlux Brightside Polyurethane. I'll check it out. I've had good luck with exterior finishes designed for marine applications during my previous life before I left the water andreturned to the Land of Enchantment.
Ken Levan
Old 05-23-2006, 09:52 PM   #14
Supposititious Blue
65GT's Avatar
Profile:  1953 21' Flying Cloud
1965 20' Globetrotter
WBCCI Metropolitan New York Unit #072 , New York
Images: 26
Here's a polishing article from the Wally Byam Caravan Club's Blue Beret magazine -- Phred Sez feature.
http://www.wbcci.org/documents/Phred...02004_0001.pdf
It's the footnote that I keep remembering. I've used Interlux on my boat for years and have hung on to this article because when I finally get to that roof, I'm using the paint mentioned here. Interlux self-leveling paints make a brush-on or roller-on job look like a spray on finish!
__
What's next?
6500+ Airsteam families having fun!
1100+ Airstream Events including 650+ Rallies in 2008!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Pingbacks are On
Roof Air Problams 1985air345 Mechanics Corner - Engines, Transmission & More... 22 01-28-2003 06:40 PM
Paint Repair Primer Howard Lefkowitz Clearcoat, Exterior Paint & Trim 2 08-25-2002 11:56 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
Roof AC units Questions FrankR Furnaces, Heaters, Fireplaces & Air Conditioning 15 07-22-2002 01:35 PM
Help...re Paint GOOFUP Cat Clearcoat, Exterior Paint & Trim 3 04-18-2002 08:14 PM
SEO by vBSEO 3.1.0
