Old 01-11-2017, 08:42 AM   #21
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Originally Posted by Howard L. View Post
http://www.airforums.com/forums/f142...ml#post1726310
Brian, here is a little info on what I do with the skin filiform.. match is not perfect, but much better than the corrosion unless a small area.
Thanks Howard - that looks very good. Not sure if I can get that particular Rustoleum here in Canada but will look - in any event, all being well we will soon be in Florida for an extended stay!
I have always touched up by brush painting rather than spray, because I was a afraid that the feathered overspray would tend to catch dirt over time and look grubby, but it sounds as though you have successfully managed to avoid that by a very light final sanding - maybe wet sanding might be best?
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 01-11-2017, 02:37 PM   #22
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
If you want to be safe, use 1000 wet/dry to remove the silver overspray. You can go dry since you are just very lightly sanding. Extend out over the Alcoa Clear Coat a bit also. You just need to get the sandy feel off. Wipe clean with a dry cloth then spray the clear coat over the silver paint, feathering out over the adjacent Alcoa clear coat you touched with the sandpaper. Nyalic, if you use, will feather very nicely into the factory clear and only be noticeable as an ever so slightly shinier surface. Nearly impossible to notice the different clear coat covering if you use the Nyalic. (note the caution on the thin Nyalic--Practice a small area on metal to get the "tack coat" process when spraying the stuff.)
Howard L. is offline   Reply With Quote
Old 01-15-2017, 07:34 AM   #23
1991 25' Excella
1995 34' Excella
Atlanta , Georgia
Have you considered buying the stainless steel replacement door? They are sold by both vintage trailer supply as well as the airstream store. They are available in both a smooth/plain surface as well as a riveted face. They're a little pricey, but I just upgraded this weekend and am very happy with how it looks.
vincaroo is offline   Reply With Quote
Old 02-03-2017, 03:43 PM   #24
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
there a "little" pricy.. how about a LOT pricy..nice can of paint and looks just as good for a whole lot less,, more money for beer and fuel "_:
they do look nice,, the SS ones.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
To Paint or not to Paint my AC Cover? jdlimages General Repair Forum 11 07-08-2015 10:11 AM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Paint for water heater door nbka1bm Water Heaters, Filters & Pumps 20 06-23-2008 04:10 PM
paint or not paint PeterH-350LE Airstream Motorhome Forums 15 01-22-2003 09:27 AM
What kind of paint for a louver cover for a wall panel heater CindyH General Interior Topics 1 09-19-2002 08:38 AM
