Old 11-02-2012, 07:58 AM   #1
1985 29' Sovereign
Richmond , Virginia
Old stripe removal
Hi all...I have an 85 sovereign that I am renovating. I read the trick on the forum about taking off the stripes using the wet towel/iron method...fwiw for those of you taking off stripes out there, it is waaaay easier to get a heat gun that painters use, hold it 4-5 inches from the stripe, then peel away...works like a champ.
But...if you look at the pic below, the blue stripes on the right came right off with the heat gun method. Around the word "Sovereign" is another matter, the plastic is cracked, and there seems to be a different kind of adhesive on there that is really nasty stuff.
Any ideas on how to get this stuff off? Any chemical strippers I could try that won't hurt the aluminum?
Stonew98 is offline   Reply With Quote
Old 11-02-2012, 08:09 AM   #2
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
One whole side of my Excella was cracked like yours. I just used the heat gun and a lot more patience. Sal
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 11-02-2012, 08:57 AM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
I use this with a great deal of success with those new adhesives.
Amazon.com: Best-Test Bestine Solvent and Thinner quart: Arts, Crafts & Sewing
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 11-02-2012, 09:13 AM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Automotive paint stores sell a spray used to remove trim. It should work for you.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
