Old 11-09-2007, 10:01 AM   #1
S.S.SLOAN
s.s.sloan's Avatar
1987 34.5' Airstream 345
Belgrade , Montana
not sure how to remove this safely?
While the stripe removal is coming along nicely using the wet towel/hot iron method. I am left with these black stripes above and below. They are so weathered they feel like "crust". My husband says it's paint not a decal. However the more weathered spots flake off with a scratch of my fingernail. Other sections look like they are still attached. After reading many,many posts on removing decals and clearcoat I'm wondering if maybe some wd-40 and a plastic kitchen scrubby might get this off? Or should it be removed when we apply the chemical for the clearcoat removal?
s.s.sloan is offline   Reply With Quote
Old 11-09-2007, 10:16 AM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
A plastic scrubby will scratch the aluminum.
As far as chemicals. Acetone or MEK with a COTTON rag will take the paint and everything else off. They are non-corrosive. You will need to use it in a well ventilated area dn a resperator is mandatory.
Michelle TAC MT-0
Sarah, Snowball
Old 11-09-2007, 10:50 AM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
If you are going to strip & polish anyway...the remaining residue can be removed with the stripper, no need to get the black off separately. Just make sure to remove any plastic lenses or trim that you don't want damaged - the Aircraft Stripper especially will eat them up.
Shari
Old 11-09-2007, 12:01 PM   #4
S.S.SLOAN
s.s.sloan's Avatar
Belgrade , Montana
thanks thecatsandi and insideout! It's great to have two options. I will use them as plan a and plan b. It will depend on how soon the clearcoat projects happen. If that takes way too long to get started I will probably take the strips off with the MEk. We used to have some handy but might need to get more since the move.
Old 11-09-2007, 02:28 PM   #5
GoNomad's Avatar
1975 Argosy 28
Anderson , South Carolina
Remember to wear rubber glove when using MEK. Prolonged skin contact is almost as dangerous as breathing it in. When I was a aircraft mechanic we used to use MEK to wash our hand until the MSD sheets proved this to be foolish and dangerous. Liver damage is not worth it.
Nick & Holly
1975 Argosy 28 Rear Bath 1963 Shasta Airflyte
2008 Toyota Tundra Double Cab SR5 5.3L 4x4
"We've got PBS minds in a MTV world" J.B.
GoNomad is offline   Reply With Quote
Old 11-09-2007, 06:45 PM   #6
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Wait! If it's truely a decal, you can buy an attachment that looks like a huge rubber eraser from an auto body shop around you. It's made to take off decals. I put one in a 1/2" drill (it's made for an angle grinder) and used three to take decals off a delivery van... no stripper needed! I'd try this first.
Marc
Old 11-09-2007, 10:04 PM   #7
Keymar , Maryland
Nitryl gloves to be exact. Latex will melt. Should have mentioned this earlier.
Michelle TAC MT-0
Sarah, Snowball
Rv Safely and RV Lemon Laws Whisler6 General Motorhome Topics 3 09-21-2006 03:34 PM
Getting on the Roof Safely/Replacing a/c shroud Nicksut Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-05-2006 11:12 PM
How can I safely purchase Airstream online? sukiandmarc Buyer Guidelines 14 01-21-2006 09:45 PM
How much can I safely tow with my 99 Lincoln Navigator? tslanier Tow Vehicles 9 11-06-2005 06:14 PM
Which A/S can we tow safely with our Toyota? silvernewbie Tow Vehicles 15 03-01-2004 07:53 PM
