Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 06-06-2017, 10:15 PM   #1
Columbia , Alaska
Missouri AS needs complete stripping and refinishing.
Hey folks! Glad to be a part of this group. Really need some advice. I have an '88 25' Sovereign that has never been touched outside.
As I'm a 63-yr-old female, am considering hiring this out. Would love to find someone fairly close to Missouri but guess I could drive it most anywhere if they gave great service.
Really look forward to your ideas! Thanks so much!
ngcarper is offline   Reply With Quote
Old 06-07-2017, 11:11 AM   #2
Columbia , Alaska
Since I haven't had a reply[emoji30], am I to assume my best alternative is to take it to the place in Ohio? I thot perhaps there was a place closer, Chicago area perhaps?
Old 06-07-2017, 04:16 PM   #3
garyr's Avatar
1987 25' Sovereign
Emporia , Kansas
Might check-out: airstreamguy in Marion KS. Not too far from KC. I have never had any dealings but he might be close.
Gary
garyr is offline   Reply With Quote
Old 06-07-2017, 10:44 PM   #4
1979 23' Safari
Wayland , New York
Try giving Mike at timetestedrestorations.com a call, he's mobile, works out of his '66, so if you have a parking spot he might be available.
Old 06-08-2017, 11:11 AM   #5
1993 32' Excella
Woodburn , Kentucky
P and S Trailer Services in Ohio is an excellent choice to do this work, in my opinion. I have a '93 Excella that they polished and clear coated. They did excellent work. Their web site is www.pandstrailerservices.com. This work is not cheap no matter where you take it. I am sure there are others who refinish AS trailers, I just do not know any of them. Good luck.
David Parker
1993 Excella
1989 Dodge D-350
davidlparker is offline   Reply With Quote
Old 06-08-2017, 11:22 AM   #6
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I would let this run for at least a week or two. There are a *lot* of people who only check in every few days.
Old 06-08-2017, 11:41 AM   #7
Tom T
Tom_T's Avatar
Orange , California
Hi NG,
As a 64.5 year old male - I think it's a good idea to hire it out, unless one is a glutton for punishment!
Some of the vintage Airstreamers here in CA have used is the truck services who polish the shiny tanker trailers you see in the 18-wheeler rigs, & those are all over the country & often/usually associated with truck stops & other services for the truckers.
I've not used one personally, since so far we're keeping our `60 Avion T20 with it's natural patina, so I can't speak to it - other than in talking with several AS owners who used them to great effect, & according to them it lasts longer than the shines done by the "cyclo" machines so popular with the AS resto shops.
Apparently the truck polishers use huge 36"-48" buffing wheels on edge & polish vertically, giving a more consistent shine. While I'm sure that the cyclo fanatics will chime in that it cannot work well without leaving lines - but I do know that in auto concours in which I judge, that we do try to do all final polishing, waxing & wipe-downs etc. in a line horizontally to fool the eye in the sun. The 18-wheeler tankers & AS's are taller than cars, so they do it vertically, again to fool the eye. I can also say that upon close inspection of the one guy's 63 AS, I could see no lines from the vertical polishing & buffing at all.
One suggestion from the guy with the 63 was to remove all the accessories like antennas, vent caps, latches, hold-downs, handles, etc. before sending it to them to polish, just to be safe & to get a good polish (18-wheel tankers don't have those types of obstructions), as you would probably do with a cyclo job too. Then those smaller parts can also be more easily hand polished as needed off of the trailer.
So being far away, you may want to hire somebody to do that removal/polishing/remounting of the small parts for you as well.
The guy also said that it was about 1/2 the cost for their polishing job, than what the resto shops are charging for their cyclo jobs, & it typically lasted several years without any repeat hand nor buffer polishing. He had a finish spray applied product he used in between to keep it nice by hand wipe-down, but I can't recall it's name now (half-zymers at 64! ;-).
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
Tom_T is offline   Reply With Quote
Old 06-09-2017, 05:50 AM   #8
Half a Rivet Short
2022 Interstate 24X
Hi
No matter how you do it, any "buff and polish" job will take off a bit of metal. That's just the way things work. It may not be a lot of metal if the process is done right. You are dealing with soft aluminum and not stainless steel. It is quite possible to go overboard.(actually it's *really* easy ... don't ask how I know). Repeat the process a few times and the result may be a bit "exciting".
Old 06-09-2017, 12:53 PM   #9
1969 27' Overlander
Burns , Kansas
There is a business just north of Rodgers Ark. called Hoss's RV Repair and Restoration that work on mostly Air Streams I believe. Never done business with him but he was very helpful and seems knowledgeable. I seen several AS sitting there he had polished so he does do it. We happened to drive his stretch of road last fall and as I passed by I saw a yard full of silver birds and whipped it around and pulled in. And since we had just started our first total rebuild of a 69 Overlander I had a lot of questions. And as it happened it was Saturday afternoon and all his hired help was gone so he sat and visited and showed us around and give us ideas and info. Don't think he has a website but rather Facebook. My wife follows him but I don't do FB. Google is your friend.
Rod
rocar-ks is offline   Reply With Quote
Old 08-26-2017, 02:33 PM   #10
1992 29' Excella
Powder Springs , Georgia
David Lee Park, with a 1993 Excella, can you share photos of the work done to your trailer at P & S? Thanks
Deja-vu is offline   Reply With Quote
Stripping out the complete inside of a 1971 Airstream Landyacht Overlander 28' Excellent condition Iandrury Airstream Classifieds 0 03-13-2017 11:32 AM
Just bought a 1963 that needs a complete restoration. OklaOverland Member Introductions 11 07-20-2015 11:52 AM
1969 airstream trailer needs work complete appliances NO RESERVE eBay Watch Airstreams on eBay 0 02-04-2014 03:00 PM
1957 Airstream Trailer,very complete,needs restoration, eBay Watch Airstreams on eBay 0 03-18-2009 12:40 PM
'64 Overlander, Needs Complete Overhaul... Worth It??? bechand0128 Trailer Values 4 04-08-2006 09:56 PM
