Old 06-23-2008, 06:31 PM   #1
airhead2's Avatar
1962 24' Tradewind
1955 16' Bubble
2006 25' Safari
Burlingame , California
Looking for paint for 2006 AS frame
I have a 2006 Safari SE LS Front Bed (love it)!
The frame section near the hitch of my AS has some nasty scratches .
You know what AS I'm talking about. Does anyone here have a source for the correct brand and color of paint used by AS so that I can touch up these spots, or some advice as to what to do (or what not to do )?
Thanks in advance for the help!
airhead2 is offline   Reply With Quote
Old 06-23-2008, 06:36 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I seem to remember the color is "Sears Toolbox Grey".
Old 06-23-2008, 07:45 PM   #3
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Airhead,
Check with your AS dealer. They should sell, or can order for you, the hitch paint you need. It is a quality automotive that comes in a spray can...cost, about $15. There are two colors you can use. The color that should be on your AS is the 360260-100 Pewter Gray(non-metallic). You can also use a metallic paint, which I like better and ended up repainting my A-frame as well as my Hensley Hitch. The AS number and color is Dupont Metallic Gray. Part No. 360151-01.
If you have some rust, a rust neutralizer works well prior to painting. I use Extend rust neutralizer made by Loctite and it works good. There are plenty of other brands out there though.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 06-25-2008, 12:18 AM   #4
airhead2's Avatar
1962 24' Tradewind
1955 16' Bubble
2006 25' Safari
Thank you. My concern was that the color/shade may be different year over year (trying to learn from my former mistakes). I have seen posts regarding frame paint on the forum, but for earlier years, so I thought I would ask.
Overlander63 mentioning Sears Toolbox Grey sounds spot (will check it out), but I will call the local AS dealer as well.
Thanks again
Old 06-25-2008, 07:29 AM   #5
2007 25' Classic
Hydes
I just bought two cans of the Airstream Grey from my dealer and they were $20.00 each. After spraying my Hensley, I don't like the quality of the paint. It doesn't seem to dry as hard as some enamels and it scratches easily. Buy another brand, you probably get better paint and spend a third as much.
craftsman is offline   Reply With Quote
Old 06-25-2008, 02:14 PM   #6
2007 25' Classic
Hydes
Just wanted to say the Airstream touch-up paint is so bad that I'll be stripping it and repainting the Hensley( a lot of work to do it over).I used Sikkens to paint my Land Rover and this stuff is junk.
Old 06-25-2008, 03:45 PM   #7
Well Preserved
1993 21' Sovereign
It wouldn't hurt so much if it was only a couple of bucks for a spray can, you can afford to repaint every year or two. $40 a year to touch up is a bit steep.
Old 06-25-2008, 04:54 PM   #8
TinShack's Avatar
2005 28' Safari S/O
I worked great for me. It's been on almost 2 years and still looks as good as when I first painted it. $20 is high though and I would certainly look for other options at that price. $15 was bad enough.
Steve
Old 06-29-2008, 02:29 PM   #9
2008 19' Bambi
Charlottesville , Virginia
Pretty good luck with paint color...
After purchasing our 2008 AS Safari 19, I noticed some scratches and spots of rust on the frame. The color AS used looked pretty close to a paint I had in my shop, so I tried it out. As it turned out, the color was nearly identical.
I used Benjamin Moore's Alkyd Ironclad Low Lustre Metal and Wood Enamel
(prevents rust, for int/ext application) Deep Bronze color #4956213.
I went ahead and used this paint on the inside of the rear bumper storage compartment and on the inside of the bumper itself.
This paint takes a little while to dry, but the final finish is hard and very durable. I have used it over the years to paint metal working machinery in my shop and have been quite happy with it.
Harper is offline   Reply With Quote
Old 06-29-2008, 02:54 PM   #10
1986 31' Sovereign
Miami , Florida
I have an older trailer (86) and the previous owner did all the grey with Duplicolor SUV Gunmetal Metallic. Looks good and is far cheaper than the Airstream paint. Don't know how close it would come with a newer trailer but you could make a cardboard "sample" and see if it works.
mike
frame, paint
Paint for frame Rob30044 Clearcoat, Exterior Paint & Trim 2 11-27-2004 02:54 PM
What Paint for Tradewind Frame?? gtr Interior Restoration Forum 4 10-12-2004 04:49 AM
Tongue/frame Paint campcollector 1997 - 2004 Bambi 15 06-15-2004 02:20 PM
Frame Paint George Jr. Clearcoat, Exterior Paint & Trim 4 04-06-2003 06:55 AM
Paint for frame and tongue dmac Clearcoat, Exterior Paint & Trim 3 01-15-2003 04:39 PM
