Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 09-13-2003, 09:24 PM   #1
aviontt
aviontt's Avatar
Profile:  , Connecticut
Lightbulb Just wondering?
Have read some about the painting of an Argosy. But has anyone painted an Airstream? Polishing is great except all those little dents and deep scratches would be easier to fill with Bondo and paint extra awning holes etc. etc.......Just wondering....
aviontt is offline   Reply With Quote
Old 09-14-2003, 04:05 AM   #2
71tradewind
71tradewind's Avatar
Profile:
I saw one painted once, it looked bad and
was peeling just like the clear coat does on unpainted ones.
71tradewind is offline   Reply With Quote
Old 09-14-2003, 05:40 AM   #3
74Argosy24MH
Profile:  LOST , Hawaii
Aluminum trucks, trailers, airplanes, and Argoys have been painted for years, no reason an Airstream can't be painted. There are members who have done it on both trailers and motorhomes and said it was indistinguishable from a fairly short distance.
Metal prep and proper primer are key, it will have to be sanded and use an etching primer, if not it will peel like clearcoat.
John
74Argosy24MH is offline   Reply With Quote
Old 09-14-2003, 06:05 AM   #4
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
They paint Aircraft !!
My 2 cents !
If aircraft have the same skin as an AS and are painted then painting the AS should be no problem.
American Airlins keeps the shine the rest paint. The downside on painting aircraft is the weight.
On an Airstream I don't think weight would be an issue but the right technique would be critical.
Garry
Old 09-14-2003, 08:37 AM   #5
Astrodokk
Astrodokk's Avatar
Profile:  Santa Rosa , California
My MH is painted and everyone thought it was polished. That is, until recently when I was powerwashing it and the paint started peeling from the right side area around the fridge access door. The metal underneath is a beautiful shiny aluminum, so it looks like the proper prep was not done to this. Actually, I'm considering removing all the paint if it gets worse, and keeping it stock shiny.
Astrodokk is offline   Reply With Quote
Old 09-14-2003, 01:16 PM   #6
zduke4x
zduke4x's Avatar
Profile:
painting problem areas
As a person with quite a lot of body shop experience, the area you mention is typical of the areas that get "glossed over" by body men and painters. Sanders and power tool as well as sprayers shy away from edges that are hard to work, so it may be that this is an isolated weak area in the paint process.. I hope so, then it is less of a worry, just needs some spotting to repair....lol...jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 09-14-2003, 05:34 PM   #7
dinoburb
dinoburb's Avatar
Profile:  1982 34' Limited
Tidewater , Virginia
Now don't let Andy see this!!!
Just kidding Andy!
As a retired Navy pilot (A-6E) and aircraft maintenance officer, painting of aluminum is both practical and doable (is that a word?). There are several caveats that must be observed:
The skin must be CLEAN.
You MUST use a paint designed for aircraft aluminum.
And finally, (Andy look away!) you MUST etch the skin with a solution of alodine or similar aluminum prep. This is a mild acid etch and chemical conversion designed to provide a proper surface for the paint to adhere. Without this etching and conversion process, aluminum's natural surface corrosion, which starts as soon a new (fresh) aluminum is exposed to the atmosphere, will prevent proper adhesion of the paint hence the peeling. Sanding of the aluminum is not enough as all this really does is expose more surface to the atmosphere so new corrosion begins immediately.
The reason I tease Andy is that he fears, with reasonable history, that the etching process will produce leaks at the rivets. Any rivet that will leak with this prep will leak without it due to the working of the rivets while the coach is in motion.
I supervised the painting of aluminum aircraft for 20 years and any failure of the paint job could be traced to three things: wrong paint used, improper application (technique, temp, etc.), or failing to etch (the etch also provides a protective surface coat to prevent oxidation) the surface first. Failing to etch was the cause in over 80% of the paint failures I investigated.
Naval aircraft are subject to some rather harsh extremes not the least of which is maintaining a seal to allow for cockpit pressurization. Can't afford too many leaking rivets here!
Hope this helps,
Sean
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 09-14-2003, 05:53 PM   #8
Coloradobus
Profile:
SILICONE REMOVAL
Dinoburb,
We tought about painting our Globetrotter. But now, we would rather have it al-you minium shiny. Our '67 Globetrotter came to us ladened with clear silicone on most of the roof seams.
We have an apparent leak, not along a seam, but a few loose rivets on the front upper left roof panel. NOW, how do you get all the bleapin' silicone off so we can use the Vulchem?
I have been carefully scraping with a razor blade, but not all of it comes off. Scrape too hard and you scratch the aluminum. Any suggestions. anyone? I was hoping to finish before we get any more moisture.
Coloradobus is offline   Reply With Quote
Old 09-14-2003, 06:39 PM   #9
COArgosy78
Obsessed with Moonunit
COArgosy78's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
Love It Here , Colorado
Images: 45
This is not an AS, but i thought i remembered seeing the picture in our photo gallery. Posted by F23Bone at the Tin Can Rally of 2002. Gives you an idea of what a paint job can be!! Got lots of really nice comments on the picture. Hope they don't mind me posting it here for you. Leigh
COArgosy78 is offline   Reply With Quote
Old 09-14-2003, 09:27 PM   #10
Holzarbeiter
Profile:  1978 31' Excella 500
Goose Creek , South Carolina
I have a painted A/S and started stripping it today. I dont know how long ago it was done but it was done right. Still the paint was peeling at the front corners as well as most of the roof. I will try to polish it if i can get all those damn scatches out. I wouldn't paint if your skin is in good shape, airplanes need to get stripped and painted on a regular basis. Granted that they go through extreme temp changes but paint also needs care, think of your truck.
If anyone has any info on dealing with deep scratches, please let me know
Holzarbeiter is offline   Reply With Quote
Old 09-14-2003, 09:35 PM   #11
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: SILICONE REMOVAL
Originally posted by Coloradobus
Dinoburb,
Well I know brake cleaner will cause RTV silicone to loosen up. Not sure it's all that good for the aluminum.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-14-2003, 09:41 PM   #12
Holzarbeiter
Lacquer thinner should work as well, I washed stuborn areas with thinner and steel wool, worked out well and if you use a fine wool the sratches should polish out.
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 08:15 PM
"Water Heater" & SS Flex hose? Sneakinup Water Heaters, Filters & Pumps 15 01-31-2004 10:22 PM
OK, here's another lame idea... drboyd Axles 27 07-07-2003 10:15 AM
Wider front wheels and tires CBBOB Airstream Motorhome Forums 7 02-13-2003 09:20 AM
