Old 10-09-2014, 11:02 AM   #15
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Be very sure to remove all plastic items, light lenses, etc. before using the stripper. It will badly mar any plastic. Even when applying the stripper carefully with a brush, when you wash it off, it will damage plastic parts.
Don't even ask how I know.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 10-09-2014, 11:06 AM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I stripped mine a few Airstreams ago and only waxed it. Actually I used Liquid Glass, it was shiny enough for me and held up a long time. I taped over the light lenses and any plastic before stripping.
1966 Overlander
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
Our AIRSTREAM and TIN CAN TOURIST Rallys
Old 10-09-2014, 11:26 AM   #17
Splitrock's Avatar
Sioux Falls , South Dakota
I used Citri Strip and power washed hot. Didn't have any leaks from washing. I polished right away. My trailer probably only had half of it's clear coat left on it anyway.
I can't think there'd been any problem with not polishing right away except I'd have to wash it again before polishing. Not a big deal at all.
Old 10-09-2014, 12:55 PM   #18
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by rothway View Post
I am stripping the clear coat on my 1971 25 foot Caravanner International tomorrow. I have 5 friends helping and we are using Aircraft Paint Remover. We will brush on the Aircraft paint remover then power wash off the clear coat. I do not plan on buffing for many months and wonder if this is a problem for possible rusting or??
For now, is there any quick and simple way to polish without taking 200 hours? Is there any quicker hand and towel polish that would work if I had just man power?
I used Citri-Strip on my front end caps of my Excella last winter. I waited about a week afterward to start refinishing with clear coat. I started getting a grayish white haze from oxidation that I had to get off before spraying the finish. If you are going to polish later I doubt the little bit of corrosion will matter. Though, if you are in an area with acid rain or industrial pollution fallout you might get some streaking/staining.
The quick and easy way to polish: get someone else to do it
Alan
Old 10-09-2014, 05:41 PM   #19
1993 25' Excella
CLeveland , Ohio
I used aircraft stripper, plastic scraper and the pressure washer to remove the clearcoat. After that we removed/replaced most of the caulk along all seams, used alumibond (eternabond) cut lengthwise in half to cover all rivets on the roof to avoid any leakage up on top forever and then sealed each rivet one by one with a sealant. We have started to polish but will continue with that project next year.
Akronguy is offline   Reply With Quote
Old 10-09-2014, 07:06 PM   #20
Perry & Sam
luvtocamp's Avatar
1969 27' Overlander
Conway , South Carolina
We have began the stripping and polishing process. This is my first time and am learning a lot about what steps not to do before the others. We are using aircraft striper. It works well and fast. Discovered it works best to do a small area at a time. Not much more than about a 3ft x 4ft. I got greedy and tried too big an area and it dried hard and had to reapply stripper. Brushing it on and then using a soft scrapper like a body filler applicator. Water pressure from the garden hose works good too. Would suggest not using a pressure washer unless you have a wide fan tip and are experienced with operating one. I got the idea to just polish a spot to see what it would look like before completing the whole stripping process. Looks great but I think I would have been happy with the stripped finish without polishing. Oh well, that's in the past now, no turning back. Gonna finish the polishing and make her really shine. Glad that it's cooling off now, could not imagine trying to polish an Airstream in the summer heat.
Another tow vehicle coming SOON.
1979 Dodge Lil' Red Express
luvtocamp is offline   Reply With Quote
Old 10-27-2014, 06:12 PM   #21
Hail on wheels
GeGe's Avatar
1992 25' Excella
Little Elm , Texas
I used Citri strip and just washed it off with my hose attachment, no pressure wash. It worked great. This was after using aircraft stripper which ate thru my expensive chemical proof gloves and eventually thru it's original
container. I would choose Citri strip any day.
Gege
GeGe is offline   Reply With Quote
Old 11-09-2014, 10:14 AM   #22
2017 19' Flying Cloud
Madison , Wisconsin
Send a message via AIM to jtwind Send a message via MSN to jtwind Send a message via Yahoo to jtwind
My dealer said to use pledge revitalizing oil on the outside of new bambi. Claimed that was from airstream. Anyone else heard of this?
jtwind is offline   Reply With Quote
Old 08-01-2016, 06:02 AM   #23
1993 29' Excella
Wasaga Beach , Ontario
Originally Posted by airdreamers View Post
Check out Flitz used with a light duty ball buffer Demo on YouTube, search it! There is hearsay that there was or is a small sample in the newer Airstreams. I used it on my end cap, works great. Kleen stripper from Lowes.
was the KLEEN Strip just the paint thinner - I'm in Canada and sometimes Lowes et all change products north of the border - anyone know for sure?
airbusjudy is offline   Reply With Quote
Old 08-01-2016, 06:31 AM   #24
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
yep....been using a PW for years, I rationalize, it's like rain at 60mph.
From Factory PDF...
DON’TS
• Leave window and vents open.
• Wash Trailer When Skin Is Hot
• Use abrasive cleaners
• Use Chlorine Products
• Hard Bristle Brushes
• Wipe against grain
• Forget to Pre-wash
• Use Pressure Washers closer than 30” & above
2500 PSIG with less than 40 degree fan tip
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-02-2016, 07:05 PM   #25
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Yes Kleen Strip is the brand I used, but I think any stripper would do. Let the stripper whatever brand it is do the work, leave it on for a good while
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Strip Clear Coat 1976 adonh Cleaning, Stripping & Polishing 7 03-17-2010 05:47 AM
Easy polish over new clear-coat Phantom Cleaning, Stripping & Polishing 16 04-21-2009 08:33 PM
strip clear coat w/out polishing bridger Cleaning, Stripping & Polishing 5 07-08-2006 07:25 PM
strip clear coat baobi Cleaning, Stripping & Polishing 3 05-28-2006 05:29 PM
