Old 12-21-2013, 09:25 AM   #15
Originally Posted by Ganaraska View Post
This guy charges $180 a foot
airstreamguy.com - Polishing Information step by step here**
120 or 150 sandpaper seems pretty harsh, I would think you would use 400 or 360. 120 is for smoothing plastic filler or cutting down primer.
I could see painting an Airstream but only if it was not feasible to polish it or leave it alone, for example if you did some repair work and used filler to get it smooth. Then you would have to paint.
If I did paint I think I would find a better color than silver. Paint to match the tow car, or some original color scheme.
The proof of performance, is in the pudding.
Using that heavier grit paper, gives the flexible primer far greater "bonding" strength to the metal.
Paint does not stay bonded to aluminum very well if the metal is simple scuffed.
Our paint can only be removed with stripper, as it will not flake or chip off.
Why??
Heavier grit sanding.
Old 12-21-2013, 10:22 AM   #16
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Orbital sander or by hand?
Silverflames is offline   Reply With Quote
Old 12-21-2013, 11:48 AM   #17
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Originally Posted by Inland RV Center, In View Post
Then 2 double wet coats of flexible primer should be used.
If someone wants the special silver metallic paint formula that we used, please ask and I will be glad to post it.
with apologies for my ignorance, what is meant by "2 double wet coats?"
what primer product are you recommending?
and yes, please, what is the special silver metallic paint formula?
thanks! and Happy Holidays, Andy!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 12-21-2013, 12:09 PM   #18
A double wet coat is when you over lap the spray pattern 50 percent.
The formula later when I am at the office.
Old 12-21-2013, 05:19 PM   #19
Here is the formula for the special silver metallic paint that we used for many years.
This paint was applied over a double wet coat of "flexible epoxy based primer".
Let the primer age for about 24 hours.
SPECIAL SILVER EXTERIOR PAINT
All of these liquids are Dupont products.
32 oz 814 silver
16 oz 150
32 oz 175
64 oz 7175
1 oz 259
Immediately after applying 2 double wet coats of the silver, apply 2 to 3 double wets coats of Dupont 3500 S clear.
Solarized paint? (wonder if it wears out?) AIR-Quarius Generators & Solar Power 2 03-29-2012 01:23 AM
What paint primer to use? MrJ General Interior Topics 5 11-08-2011 09:30 AM
How to deal with this paint issue? Eaglemate Clearcoat, Exterior Paint & Trim 4 09-13-2011 11:46 AM
Exterior Paint Removal star kitty Clearcoat, Exterior Paint & Trim 4 07-30-2011 02:19 PM
Interior paint? Phrunes Upholstery, Blinds, Walls & Interior Finishes 5 07-02-2011 01:20 PM
