Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 08-16-2019, 09:34 AM   #1
1975 Argosy 22 Rear Door
atlantic city , New Jersey
Installing New Rub Rail Advice
Guys - can anyone tell me if this if this is the best way to reinstall the rub rail at the bottom of my trailer? I custom made it from aluminum strip I got from VTS.
Use butyl tape, then stick the rub rail on, drill the holes and fill with pop rivets with a little bit of tempro in the hole? Then seal the top side of the rub rail with a small bead of tempro? But I have also heard that it won't bead very well and I should use paranbond, or some kind of aluminum looking sealant that will be less noticeable? I've also read that butyl tape dries out - but if I use gorilla tape or something, and ever need to get the rub rail off, it'll be a mess. Besides, i think the butyl tape drying out is only an issue if its exposed?
Thoughts?
girasoledonn is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
hints for installing rub rail insert 310astream Clearcoat, Exterior Paint & Trim 4 06-13-2009 10:09 PM
ebay - BLACK rub rail 13' New Old Stock ViewRVs Airstream Motorhome Forums 2 07-11-2004 06:53 PM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
