Old 05-12-2008, 05:55 PM   #1
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Question How to remove silver paint from exterior skin?
The PO used a bit of silver spray paint around the front window and even sprayed over the Airstream plack! Nice! Question: What is the best way to remove the paint and not mar the aluminium? Tks, Z.
Zstream is offline   Reply With Quote
Old 05-12-2008, 06:10 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Start with mineral spirits, then move "up the food chain" until the old stuff comes off. Probably enamal reducer will be what gets most of it off.
Old 05-12-2008, 06:15 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Give Goof Off a try, I have good luck using it on a variety of finishes.
Aaron
WBCCI #XXXX AIR #2495
Old 05-12-2008, 07:31 PM   #4
Baltimore , Maryland
Go right to the top...MEK.
Old 05-12-2008, 07:41 PM   #5
bertro's Avatar
1971 23' Safari
Groveport , Ohio
Thanks for the ideas the PO of my safari for some reason sprayed primer around the furnace intake. Robert
bertro is offline   Reply With Quote
Old 05-12-2008, 09:21 PM   #6
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
THIS IS ONLY FOR THICK BUILD UP! AND TRAILERS YOU PLAN TO POLISH!!! Aircraft Stipper and a Copper metal brush.... The stripper will raise the paint. Then the copper brush will open it up some, it is soft so it will not leave marks with a nice soft touch... Please take your time and dont rush it may take 3-4 times with the stripper. The copper brush is used to remove only the lifted paint. Do not try to use it to rub it off! (this could leave marks)
The last step is to use a 3m pad fine to medium together with some stripper this will lift what paint is left. I use distilled water to then wash off the stripper that is remaining. NOTE: STRIPPER WILL TAKE OFF CLEAR COAT!
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Can I remove Vinyl interior skin?? racoco 1974 - 1979 Sovereign 20 07-15-2012 01:01 PM
How to Remove 57 SOTR Funky Belly Skin? asta2 Belly Pans & Banana Wraps 10 12-20-2006 07:57 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
How? remove top interior skin Zeppelinium General Interior Topics 3 03-03-2006 03:25 PM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 06:50 PM
