Old 09-05-2016, 12:16 PM   #1
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
How to remove number adhesive
Stripped the front segment with the numbers and the WBCCI decal. I cannot get the adhesive off the AL. I have used Citri strip several time and used Lacquer thinner. The adhesive is nice and clean now but it is still there. How to remove it?
Old 09-05-2016, 12:22 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
3M Adhesive Remover or a rubber decal wheel.
CRH is offline   Reply With Quote
Old 09-05-2016, 08:16 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I've had good luck with Aircraft Stripper, available at many car parts stores.
Sometimes I resort to my electric heat gun. That might help too.
David
Old 09-05-2016, 08:32 PM   #4
2007 22' International CCD
Try 'Rapid Remover' but follow the directions very carefully. Test in an inconspicuous area first.
Available online, Amazon is one source.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 09-06-2016, 01:43 PM   #5
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
goof off or paint thinner (not lacquer thinner)
twolanehwy is offline   Reply With Quote
Old 09-06-2016, 02:22 PM   #6
1973 25' Tradewind
Redding , California
+1 Rapid Remover
^^^ this stuff is amazing. +1 for rapid remover. Airplane paint stripper as well. be sure you get it from an automotive paint store, they usually keep it behind the counter. That stuff will peel the pai... oh wait that's what it's for... get gloves mask etc. it's potent.
Leadvox is offline   Reply With Quote
Old 09-07-2016, 06:09 AM   #7
LFC
Memphis , Tennessee
Heat gun..solvent...heat gun...solvent.....
LFC is offline   Reply With Quote
Old 09-07-2016, 06:25 AM   #8
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I bought a product from Menards called Heavy Duty Adhesive Remover. It's a kind of stripper that is thick & you paint it on. I tried all the other things listed above on my stripe that left the adhesive behind. This was what finally worked. I don't see it on their website, but it was at the store.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-07-2016, 08:15 AM   #9
Surf City , New Jersey
Go to a dollar type store, buy baby oil and soak the adhesive daily. It may take 30 days of doing this but you will not damage anything. It works
weber.roger is offline   Reply With Quote
Remove Insulation Adhesive ASNomads Upholstery, Blinds, Walls & Interior Finishes 12 01-05-2018 10:28 PM
How do I remove the adhesive left from stripe GeGe Cleaning, Stripping & Polishing 18 03-04-2015 10:16 PM
Mystery adhesive on patch and how do I remove it? seismicfish General Repair Forum 6 05-07-2014 09:48 AM
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 10:08 PM
