Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 08-24-2009, 03:16 PM   #1
Profile:  1978 31' Sovereign
Cincinnati , Ohio
How to remove my letters
I have a 78 Soviergn and I am in the process of polishing the endcaps. How do I remove the cast aluminun letters? I would like to polish around them, and more importantly I plan on re-painting the A I R S T R E A M letters so they look better. Are they just glued on? If so, do I just wedge them off? I do not see any rivits or screws holding them in place.
http://e-rock53.blogspot.com/
erock53 is offline   Reply With Quote
Old 08-24-2009, 03:43 PM   #2
87MH's Avatar
Katy , West Planet Houston, Texas
Images: 231
There are two or three small tits formed into the back of each letter.
These tits are about 1/8" in diameter and about 1/4" long. Without removing the endcaps you will not be able to remove the letters without knocking these tits off.
To remove the letters get a good putty knife and work it under the letters, then shear off the tits with a good wack to the knife - much the same procedure used in removing rivets on the roof without having to drill them out.
You might have to seal the holes caused by the original mounting holes. I remounted my letters (on the front) by drilling holes in the letter and using Olympic rivets to hold them on. I was able to drill out the tits as there were slight casting indentations on the front indicating where the original mounting holes were.
When I remounted the letters I put a good film of vulkem on the back of each letter to make sure no water would be trapped behind them. Be sure to seal the Olympics with a daub of Vulkem also.
I removed the front letters and painted them, then replaced them as above, but, on the rear I repainted them while they were still in place as per the picture below.
I polished the edges of the letters (under the tape) prior to taping them up and etching the rest of the casting. Paint is Rustoleum "Royal Blue"
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Remove Airstream Letters? BeckyAnt Clearcoat, Exterior Paint & Trim 13 11-19-2009 12:09 PM
What's the best way to polish between letters? Tidal Cleaning, Stripping & Polishing 4 09-20-2007 09:24 PM
Airstream Letters 75 Sovereign ostapbender Cleaning, Stripping & Polishing 3 08-22-2007 06:24 AM
How Do You Polish Around Letters? JohnG Cleaning, Stripping & Polishing 5 09-05-2004 10:44 AM
Looking for letters FrankR Our Community 6 10-14-2002 07:16 PM
