Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 05-12-2008, 05:55 PM   #1
MyFirstStreamer
Zstream's Avatar
Profile:  1963 26' Overlander
Indiana , Indiana
Question How to remove silver paint from exterior skin?
The PO used a bit of silver spray paint around the front window and even sprayed over the Airstream plack! Nice! Question: What is the best way to remove the paint and not mar the aluminium? Tks, Z.
A chief event of life is the day in which we have encountered a mind that startled us. -Emerson
Burning Man ~ Black Rock Desert Nevada 2005 & 2006 -Zstream
Zstream is offline   Reply With Quote
Old 05-12-2008, 06:10 PM   #2
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 52
Start with mineral spirits, then move "up the food chain" until the old stuff comes off. Probably enamal reducer will be what gets most of it off.
You repair things with tools. You fix things with a hammer.
AIR#2611
overlander63 is online now   Reply With Quote
Old 05-12-2008, 06:15 PM   #3
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Give Goof Off a try, I have good luck using it on a variety of finishes.
Aaron
WBCCI #2449 AIR #2495
Old 05-12-2008, 07:31 PM   #4
not the shiniest rivet
62overlander's Avatar
Profile:  1962 26' Overlander
Catonsville , Maryland
Go right to the top...MEK.
read my blog at: http://annalumanum.blogspot.com/ or view my photos at: http://picasaweb.google.com/dadofava1966/AnnaLumanum02
WBCCI, VAC, WDCU#7183
62overlander is offline   Reply With Quote
Old 05-12-2008, 07:41 PM   #5
Profile:  1971 23' Safari
Groveport , Ohio
Images: 18
Thanks for the ideas the PO of my safari for some reason sprayed primer around the furnace intake. Robert
bertro is offline   Reply With Quote
Old 05-12-2008, 09:21 PM   #6
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
golden , Colorado
THIS IS ONLY FOR THICK BUILD UP! AND TRAILERS YOU PLAN TO POLISH!!! Aircraft Stipper and a Copper metal brush.... The stripper will raise the paint. Then the copper brush will open it up some, it is soft so it will not leave marks with a nice soft touch... Please take your time and dont rush it may take 3-4 times with the stripper. The copper brush is used to remove only the lifted paint. Do not try to use it to rub it off! (this could leave marks)
The last step is to use a 3m pad fine to medium together with some stripper this will lift what paint is left. I use distilled water to then wash off the stripper that is remaining. NOTE: STRIPPER WILL TAKE OFF CLEAR COAT!
http://www.VinStream.com
"Redesigning Life & Road To Vintage Custom Trailers"
vinstream is offline   Reply With Quote
Pingbacks are On
Can I remove Vinyl interior skin?? racoco 1976 Sovereign 14 04-05-2007 04:32 PM
How to Remove 57 SOTR Funky Belly Skin? asta2 Belly Pans & Banana Wraps 10 12-20-2006 07:57 AM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
How? remove top interior skin Zeppelinium General Interior Topics 3 03-03-2006 03:25 PM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 06:50 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
Search Engine Friendly URLs by vBSEO 3.2.0 RC8
