Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 11-11-2014, 06:50 PM   #1
benicia , California
How often do you wash and wax the AS?
I don't have a place to wash the trailer so Im going to have to find the closest truck stop that has washes and hopefully does wax jobs. When and how do you care for your trailer's exterior?
cantdrv55 is offline   Reply With Quote
Old 11-11-2014, 07:10 PM   #2
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Try a waterless car wash with microfiber towels. Quick and easy. Check out Griotsgarage.com.
Landrum is offline   Reply With Quote
Old 11-11-2014, 07:13 PM   #3
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I do mine 2x year. I travel about 160 nights, so lots of rad dirt on it.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 11-11-2014, 07:16 PM   #4
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
After driving on salted roads, after driving through bugs that stick on, or any other time it gets dirty, I wash my trailer. I remove bird poop or tree sap as it happens. I wax once per year, generally before summer.
Some truck washes use acid products that might damage aluminum. Be careful!
Alan
Old 11-11-2014, 08:53 PM   #5
Great advice on acid wash. Thanks all.
Old 11-12-2014, 10:12 AM   #6
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
2-3 times per year.
I won't go to the truck wash anymore because the nozzles have too much pressure. The wand damaged the chrome rub rail strip at the bottom of the door. I can probably buy this trim on a roll at an auto parts house to repair it, but I don't want more of it to get damaged.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-12-2014, 10:24 AM   #7
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Cantdr55
What I do is pull my AS through a carwash on the way home from every trip. The bays are typically high enough, and concerns re high water pressure can be taken care of by standing back a little. You have the brush and drain for all your road dirt right there, and when you get home you're done. I wax mine once a year. Jon
B00merang is offline   Reply With Quote
Old 11-12-2014, 10:31 AM   #8
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
I'll use the wand wash places when on the road, brush and hose when at home. I try to work from top to bottom, not up into the seams.
I wax sections at a time, when I have the time and inclination. Kind of like painting the Sydney Bridge. It probably adds up to two complete waxes in a year.
Bob and Nancy
https://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 11-12-2014, 11:23 AM   #9
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
Many do it yourself car washes in our area have one outside "bay". Try to find one and use that, then pull off, dry her down and wax her. I do mine once in the Spring and once before she goes to bed for the Winter.
Enjoy
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 11-12-2014, 12:26 PM   #10
Orange , California
I', doing it at home before every trip cuz we're mostly going to vintage trailer events, like the big one near you at Pismo in May. We have a long driveway, & will soon be able to park it in the backyard under one of those tent-like canopy/garages I got.
You may be able to do the same or in the street in front, so long as you have a hose bib up front & long enough hose with a shut-off at the end for our CA drought regs. A ladder, long wand or brush/mop for the roof top center area helps.
Even if you have city laws &/or CC&Rs limiting parking it in the driveway &/or street, they usually allow a limited time there for loading/etc. - & washing would be part of that, & maybe waxing time too if you can get shade over it.
I can't speak to the wax since ours is a 1960 Avion T20 & pre-anodized skin, & I won't try keeping it polished until I can keep it under the canopy cover - both for longevity & to limit the glare off a shiny twinkie!
Cheers!
Tom (TOH)
janabanana48 is offline   Reply With Quote
Old 11-12-2014, 01:02 PM   #11
Nomad518's Avatar
2001 25' Safari
Ridgefield , Washington
I wax annually. I wash after every trip before it goes back into storage. And, if it's been in storage for a while between trips, I'll wash it when it comes out of storage before leaving. Having a clean Airstream helps maintain the finish over time and greatly increases the number of compliments received. It's also a good opportunity to look the exterior over for any maintenance issues that need to be addressed.
Nomad518 is offline   Reply With Quote
Old 11-12-2014, 01:28 PM   #12
Orcs
orcs's Avatar
2014 25' Flying Cloud
Winthrop , Washington
washing and waxing
i live five miles up a dirt road in central WA., so I wash at the end of every trip. Water is very hard so spots have to be wiped off. Be sure to use a commercial car wash solution that is safe for clear coat and says so on the label. Walbernize wax is made for the Airstream and works well. Like others I do it in sections when I'm in the mood, ends up being fall and spring.
orcs is offline   Reply With Quote
Old 11-12-2014, 01:50 PM   #13
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
It seems I'm washing it all the time to try and keep the road grime and bugs off it as best I can. That said, I have a real problem after I've washed it with water spots and tying to get them off. Does anyone have a good product they use?
I tried Windex once to get the water spots off till I read it's no good for the aluminum so I rushed out right after using it snd washed it all off again. So now I'm back wondering what to use
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 11-12-2014, 01:56 PM   #14
TinTin's Avatar
Canmore , Alberta
Doug, I use automobile detailer. I have partial bottles of a number of brands in my garage, including Meguires and Mothers. They seem to work all right for touch-ups.
Bob and Nancy
Old 11-12-2014, 02:06 PM   #15
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Doug
Hi Doug,
I use a waterless cleaner from Canadian Tire. It's called "go clean waterless". A little spray (very little) and a wipe with a micro fibre cloth and you are good to go. I do mine in less than 10 minutes. Unless it's covered in Prairie Bugs. Then it takes 10 minutes on the bow. The stuff is expensive but it works. Nice weather you are having there. Jim
Jim Flower is offline   Reply With Quote
Old 11-12-2014, 02:53 PM   #16
Nomad518's Avatar
2001 25' Safari
To eliminate water spots, I wipe everything down with a soft towel after washing (yes, this means I go over everything twice...wash, then dry). Dry the windows first then the side(s) that are in the sun next. The objective is to get all those water drips off before they have a chance to dry into water spots. ProtectAll is a great way to get rid of water spots on all surfaces. It protects the rubber seals around the windows too.
Old 11-12-2014, 03:23 PM   #17
Arcticfox's Avatar
Central , Canada
Thanks Bob - I will check at Canada Tire tomorrow to see what they have...
Cheers
Doug
Old 11-12-2014, 03:56 PM   #18
m.hony's Avatar
2013 30' Classic
Macguiars Instant Detailer is da bomb, and is comes in big bottles, too.
TAC #MS-10
Airforums #70955
Old 11-12-2014, 10:06 PM   #19
Arcticfox's Avatar
Central , Canada
Thanks I will try snd find some....
Old 11-12-2014, 10:37 PM   #20
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Wax 2x/year; wash as the weather permits (9/12 months).
Wash Wax All on Airstream exterior ghatfield Cleaning, Stripping & Polishing 6 04-01-2015 06:51 PM
What do I use to wash and wax my trailer? m.hony Cleaning, Stripping & Polishing 16 09-14-2014 12:49 PM
Wash & Wax JKCA Clearcoat, Exterior Paint & Trim 8 07-16-2013 09:05 AM
Hand wash VS power "car wash" TommyL Cleaning, Stripping & Polishing 2 04-12-2010 02:50 PM
coin car wash wax david h Our Community 1 01-13-2003 08:27 AM
