Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 09-20-2006, 02:46 PM   #15
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I've never used POR15, but could you purchase the gallon size for economy, then transfer to "disposable" plastic quart containers? I do this with house paints and wood finishes all the time.
Fyrzowt is offline   Reply With Quote
Old 09-20-2006, 02:55 PM   #16
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
I would not use disposable, I would get quart cans, I think HD will sell them.
That way they are air tight.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-20-2006, 02:58 PM   #17
Fyrzowt
Fyrzowt's Avatar
Images: 8
Air-tightness is not an issue, although there may be some other reason not to use plastic. If you purchase the plastic containers made for paint products, the lids seal nicely. Do it all the time.
Old 09-20-2006, 03:29 PM   #18
Wabbiteer
Wabbiteer's Avatar
Profile:  1973 27' Overlander
1972 29' Ambassador
Twin Mosquitos , Minnesota
It is a moisture cured paint, water vapor is the catalyst. Unless you have a deep tub filled w/ dry nitrogen gas and ensure no normal atmosphere intrudes the moist air will start the process of turning it into a solid.
Powered by Tinnitus
RE & Alt Energy Hope Chest
RE Forums
Old 09-20-2006, 03:49 PM   #19
AirConditioner
AirConditioner's Avatar
Profile:
A trick my grandfather used to due with shellacs that loved to absorb water was to do the saran wrap trick under the lid and on down onto the surface of the product to kill the airspace above it. Seemed to work for a long time.
AirConditioner is offline   Reply With Quote
Old 09-20-2006, 06:07 PM   #20
Bradjun1
Bradjun1's Avatar
Profile:  1999 34' Limited
1962 19' Globetrotter
Northern , Minnesota
it can be applied with a brush
Bradjun1 is offline   Reply With Quote
