The heat gun trick is good, I did not have goo gone at home when I removed mine. I like the product and it would have worked I just did not have any here. I used a heat gun with a plastic scraper from Pampered Chef then, mineral spirits, and then a soapy rag. Just go easy and you will be fine. Mike
ok, so I bought the 1983 Sovereign and have started the process of getting it ready for a Galveston, Tx to Portland, Or trip in late August. So far: new tires and complete brake redo, new stove and refrig ordered, upgraded to a 50 Amp service ..... and so on.
However, the numbers are a little mystery to me and I could not find the specifics in the threads ..... this one had two sets overlaying each other ...... are these just WBCCI Numbers or are their two sets of number, like a coach number and a separate number for WBCCI (have already applied for the WBCCI trick)?
If they are red they are WBCCI. As trailers get passed from person to person they frequently get new numbers since the number is designated to the family not the trailer. We have two trailers with 4122 on them. Our first trailer already had 4122 on it from many years ago. We renewed the number in our name.
I think they will come off fairly easily if you heat them with a heat gun. Then to remove any remaining sticky, I'd try go-gone.
A good place to add here that Goo - Gone will take up the old numbers too, just saturate it good...don't inhale!
.....Is there another word for synonym? " Life is like a bicycle...to keep your balance you must keep moving." Einstien, 1930...and lastly,-"Go confidently in the direction of your dreams, Live the life you,ve imagined"...Henry David Thoreau
