Old 09-13-2014, 06:18 PM   #1
1969 27' Overlander
Boise , Idaho
How are the 'AIRSTREAM' Letters Attached?
So, I have these letters on the front of my '69 Overlander:
They no longer have much paint, are oxidized, dirty, probably even fungal. I would like to remove them, but am not sure how they are affixed to the trailer. If riveted, I'll just pretty them up in place.
So how are they attached, if you happen to know?
Jamespio is offline   Reply With Quote
Old 09-13-2014, 06:25 PM   #2
x
XXXX , XXXX
The back of the letters have pins protruding rearwards through the shell and attached to the shell from the interior with speed nuts.
wasagachris is offline   Reply With Quote
Old 09-13-2014, 06:56 PM   #3
1969 27' Overlander
Boise , Idaho
I see my photo didn't post properly, I'll try again.
wasagachris, soudns like I can't remove these, or reattach them, without pulling the interior end cap. Is that right?
Old 09-13-2014, 07:03 PM   #4
x
XXXX , XXXX
You can access them if you remove the storage compartment from your end cap.
Old 09-13-2014, 07:18 PM   #5
1969 27' Overlander
Boise , Idaho
Thanks, I'll take a look at that.
Next question is how were they painted originally? Whole letter painted, or just the outside, or what? If you know.
Old 09-13-2014, 08:02 PM   #6
x
XXXX , XXXX
The whole letter is painted with the exception of the raised edge surrounding the letter. If you look at my Avitar the "A" has been finished. I painted the letters and then sanded off the edge to remove the fresh paint. Place the sandpaper flat on a table and rub the letter back and forth across the sandpaper to remove the paint from the edge.
Old 09-13-2014, 08:54 PM   #7
1969 27' Overlander
Boise , Idaho
Thanks. That looks good.
Remove Airstream Letters? BeckyAnt Clearcoat, Exterior Paint & Trim 17 04-30-2012 07:31 AM
airstream letters and nameplates manymemories Exterior Restoration Forum 1 07-27-2011 03:13 PM
Airstream Letters 75 Sovereign ostapbender Cleaning, Stripping & Polishing 3 08-22-2007 05:24 AM
how to paint letters on 1970 airstream? happydaze Clearcoat, Exterior Paint & Trim 6 03-01-2007 06:24 AM
White Plastic letters for airstream grogan Clearcoat, Exterior Paint & Trim 1 06-25-2003 01:35 PM
