Old 04-29-2009, 08:17 PM   #1
1983 31' International
Belle Fourche , South Dakota
hints for installing rub rail insert
Hi all,
I just got new rub rail insert plastic for my '83 Sovereign from Inland RV. Now the question is, what is the proper way to install it. It looks like some of the metal trim on the end of the runs are used to hold it in place. Is that correct? Also, I think installing on a cool day would be better so that the blue plastic does not shrink and shift in cold weather.
Any thoughts will be greatly appreciated.
Rick in the beautiful Black Hills of South Dakota
310astream is offline   Reply With Quote
Old 04-29-2009, 08:37 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Warmer is better, the insert will flex easier. If you have a window screen spline tool, you can insert the lower rib into the rub rail, and follow along about an inch behind on the top side with the spline tool.
Old 06-13-2009, 08:23 PM   #3
1976 24' Argosy 24
Milford , New Jersey
Rick, this reply probably comes too late but, Some people have advised to put the insert in but leave the ends long and not riveted with the end pieces. Leave it like this for a week or more to allow it to shrink, because it will. I've had it shrink on me, but that was when I didn't put the little end caps on and put a rivet through the plastic insert. George.
Gkiesel is offline   Reply With Quote
Old 06-13-2009, 08:35 PM   #4
Thanks for the hints. I've only had enough free time to install one short piece in front between the battery boxes so the information is very timely.
Old 06-13-2009, 10:09 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I did mine about 5 yrs ago and, I used the metal caps and a rivet to hold the rib rail plastic ends in place. Once you start, you could use the edge of your finger nail to push the edge in. Just get it started on one side and then...walk slowly as you feed it in. Then, at the end, cut it and, do the same as you did at the start.(metal tab and rivet)
BTW. they are still in great shape after 5 yrs ..
Good Luck.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Rub Rail, Rub Rail 'where art thou?' Radman Clearcoat, Exterior Paint & Trim 18 08-09-2017 08:27 PM
help finding rub rail insert cortney Clearcoat, Exterior Paint & Trim 13 07-29-2009 04:38 PM
Rub rail insert popping out a little in one spot... ericwarren Exterior Restoration Forum 4 10-19-2008 08:03 AM
Need help w/ rub rail RiskIt Clearcoat, Exterior Paint & Trim 3 07-24-2005 09:52 AM
black rub rail and trim insert wb13798 Airstream Motorhome Forums 2 01-30-2003 12:10 PM
