Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 02-25-2003, 07:43 PM   #1
timcumming
Profile:
Help - Im Confused
Hi Guys
Can someone help me with a little question
I am currently restoring a mini cooper which I have stripped back for a bear metal re-spray. The seams which join the panels of the mini have been cut out and welded. These welded areas will need to be reshaped using filler. My question is - for these areas should I bog dirrectly to the bear metal or to the 2 pot eatch or do I need to use something else before I bogg.
Some people have told me that if I bog directly to the metal, the car will rust under the bog. These same people have also told me that you cant bog onto eatch because it wont hold..
So you can understand my confusion
Also when they welded the seams the used a very hard grey filler (looked like something like Need-IT) do you know what this stuff is called
Cheers
Tim
timcumming is offline   Reply With Quote
Old 02-25-2003, 07:58 PM   #2
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Help - Im Confused
Originally posted by timcumming
Hi Guys
Cheers
Tim
Uhhh not sure how you found a Airstream "Camper" forum for car body work. The point of a Airstream is the bare or clear coated and rivited bodies.
I happen to know a little about body work and every filler I have ever used recomends bare metal that has been sanded with a couse abrasive to give the surface some texture so the filler will bond to it. Most fillers (as well as primers) are porus and do not seal. Once you get the filler in you reall need to get the paint on soon to create the seal. I think this is where you get the idea about the rust forming. It will form if the filler is left in a high humidity enviorment with out a layer of paint to seal it. People doing their own body work make the mistake of doing the body work and then driving around with nothing but primer and then have the rust problem.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 02-25-2003, 08:00 PM   #3
Chas
Chas's Avatar
Profile:  Austin , Texas
Images: 22
Man, now I'm confused!!!
Is this my house? Is this my beautiful wife?
Chas
Chas is offline   Reply With Quote
Old 02-25-2003, 08:04 PM   #4
timcumming
Profile:
Thank s for rely. it's starting to sound like bogging on bear metal is fine under certain conditions
Thanks for the help
Tim
Old 02-25-2003, 08:07 PM   #5
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Chas
And you may ask yourself
What is that beautiful house?
Where does that highway go?
Am I right?...Am I wrong?
And you may tell yourself
MY GOD!...WHAT HAVE I DONE?
1959 22' Caravanner
Atlanta, GA
Old 02-25-2003, 08:14 PM   #6
timcumming
Profile:
your really a unique person arnt you chas
Old 02-25-2003, 08:20 PM   #7
Chas
Chas's Avatar
Images: 22
Maybe,
But it has been a while since I have really listened to the "Heads', goes back a few years. I definitely remember something about the wife though?
Sorry Tim, but the boggin' thing just threw me off, where, dare I ask, do you hail from?
Chas
Old 02-25-2003, 08:22 PM   #8
timcumming
Profile:
new zealand mate
Old 02-25-2003, 09:01 PM   #9
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Here in the south, this is what we concider "boggin'"
Yes, that's me. In 42 inches of mud.
1959 22' Caravanner
Atlanta, GA
Old 02-25-2003, 09:10 PM   #10
Chas
Chas's Avatar
Images: 22
Ohh Yeahh!!
Now that's boggin!!!
BTW, where's the Airstream? Hopefully high and dry?
Chas
Old 02-25-2003, 09:23 PM   #11
68 Overlander
Commercial Vendor
Profile:  Boise , Idaho
Images: 21
Toaster,
Watch the road ahead and don't look back at the camera...it's getting deeper
Old 02-25-2003, 10:00 PM   #12
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Originally posted by 68 Overlander
Toaster,
Hehehe that was a comlete sucker hole. It didn't look deep at all and it was right in the middle of a heavily traved trail. I avoid that stuff. I HATE cleaning the truck after that and it get's into everything. That took out a couple U-joints and most of a Sautruday going through the front wheelebearings making sure they were not damaged. The brake peddle was half covered in muddy water. Thankfully I built that truck for that kind of mess. No interrior to speak of, no carpet and the inside is pretty garden hose friendly.
What I don't have a picture of but my friend has a video tape of is the recovery. My plan was to fling the door open as I was being pulled out to drain the floor out. The rear of the truck is a step up and I had one of my Jeep buddies soft doors laying in the back as well as some camping gear.
Durring all the fun while they were getting ready I was hanging out the door being a ham for the cameras. I inadvertantly leaned on the door lock. So they hook a 30ft recovery strap to a fiends truck. I'm waiting with hand on the door latch. He starts pulling and the truck starts coming out, I can't get the door open. I figure out I locked the door. Water is sloshing all over the place, Just as I reach the other side I get the door unlocked. Well half the club is standing there taking pictures laughing at me when I fling open the door and 50-60 gallons of muddy water comes out the door sending all of them running from the mud tidal wave hahahah.
1959 22' Caravanner
Atlanta, GA
Old 02-25-2003, 10:14 PM   #13
68 Overlander
Commercial Vendor
Images: 21
Toaster,
That was too funny. I can only imagine and have nearly been there myself. So when that Ford finally pulled you out, did you thank him?
I hope you know I'm kidding
Old 02-26-2003, 06:20 AM   #14
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 35
Mini Cooper
Man o Man.. I used to carry some heavy loads with my Cooper when I was a teenager but, hey..........do you think it would haul a Bambi
Hey John....if I try the Bambi can I borrow your Hensley???
Yup... Used to like those Yakkin Heads.
confused Argosy newbie Dave Cole All Argosy Trailers 23 09-15-2006 09:36 PM
Now I am really confused Theo Plumbing - Systems & Fixtures 5 01-25-2004 03:19 PM
Confused by perfect polish Safari Tim Cleaning, Stripping & Polishing 15 08-08-2003 10:39 AM
Confused by Conflicting Reports SteveB2 For Sale & Wanted 16 05-05-2003 04:28 PM
Furnace/catalytic stuff davidz71 Our Community 8 12-14-2002 05:45 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
