Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 07-05-2003, 10:06 PM   #1
mlmarch
Profile:
front end vinyl trim, misc trim
I would like to replace the vinyl trim-85 345- also anyone have parts numbers for windshild wiper assembly. Does anyone have a paint number for the dark gray paint at coach bottom and front top around windshield? Any ideas for giving the front grille a new shine or look?
mlmarch is offline   Reply With Quote
Old 07-06-2003, 06:42 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
I am not sure about the no for the grey paint on your year..on my 82 it matches a Dupont paint number, but I think it is lighter grey than your year...maybe a 345 owner will verify.
For the vinyl trim, depending on the width, you should be able to customize it if that is what you have in mind, buying striping tape which comes in wide widths used on trucks and boats as well as rv's. I used a 3" wide to redo mine replacing the wood look.
HERE IS A PHOTO--
http://www.airstreamphotos.com/photo...papass=&sort=1
Old 07-06-2003, 07:19 AM   #3
74Argosy24MH
Profile:  LOST , Hawaii
There are a bunch of parts in the wiper assembly, but if you go to Cleveland Ignition they should have what you need.
John
74Argosy24MH is offline   Reply With Quote
Old 07-07-2003, 07:41 AM   #4
mlmarch
Profile:
vinyl trim
ALANSD
The photo looked great. How did you get off the original tape? I would like to get rid of the wood look also. I think your new stripe added a lot to the looks of your MH.
Did the tape leave residue etc?
Old 07-07-2003, 11:29 AM   #5
ALANSD
I started to pull the old wood grain off at one end, it was on there and not wanting to come off- used heat and still wanted to come off in pieces. So I cleaned it all really well and taped over it. It gave me a guideline to work with, and then new striping has been on quite awhile now with no adverse effects. The underneath black really wide striping was there from before, and just added to the look and blend of the new 3" stripe which is actually 16 stripes on one roll, that you apply all at one time. Black/silver/ and red center.
I got mine in 150' roll from a guy on ebay who was very helpful and sells quite a bit of this stuff. I have enough left to do the motorhome again twice.
here is one he has on there now
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2422679687
I want to replace the upper black 2" stripe that runs the length of the coach...but not yet found thick black in that size...still looking.
front end alignment wb13798 Mechanics Corner - Engines, Transmission & More... 2 12-11-2003 01:11 PM
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 11:13 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 05:40 PM
exterior work at front end mlmarch Airstream Motorhome Forums 4 05-04-2003 08:25 AM
front, end cap George Ribs, Skins & Rivets 9 04-07-2003 05:48 PM
